FS: 1993 RX-7, LS2 6.0L, 6 speed, Cobra, 99-Spec, Work, Tein, tons of new parts!
Old Dec 13, 2014 | 02:03 PM
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
Year: 1993
Make: Mazda
Model: RX-7
Price: $29500
Mileage: 112000
Color: Stargazer Black
Location (State): AZ
Transmission: Manual
Drivetrain: Rear Wheel Drive
I am going to miss this one. No stories, no nonsense, a well-built, well-maintained machine. I've used this for auto-x and road race in the 4 months I've owned it and loved every second. She's solid, fast, and reliable.
I've included the original post from the previous owner, but added my maintenance / mod list below it.
There are some minor exterior flaws, but no huge scratches, dings or dents. Most notably a clear blemish that sits on the rear quarter panel where the wing makes contact with it. It cannot be seen with the hatch closed. There is a hole in the rear bins which can be seen when you pull out the subwoofer board / cover, I used it to route cables until I purchased the enclosure and routed them under all the rear plastics. Getting some interference from the stereo, I probably need to isolate the ground, but it's tolerable.
I'll be replacing the A/C compressor and getting a recharge done as well. The A/C work great prior to the compressor giving out, but I'll ensure it's working properly for the new owner.
My biggest changes were to the interior, new door handles (I have a new from japan, oem mazda passenger piece with grip as well as an installed sakebomb handle), new gauge cluster/hood, new gauges, new center console, new a/c panel, customization by Toby Broadfield with the speedhut gauges (shipping week of 12/15, hoping for pics on 12/14), removing the quad pod, etc. The plan is to install of this stuff once it arrives, which should happen the week of the 22nd. Whether or not they are installed, I will include them with the sale of the vehicle. Stereo is using Focal AC series with a JL 10w3 and a Alpine PDX v9.
Speedhut with custom pod is Red Tach, other gauges are blackface / amber lettering. Fuel level, oil pressure, water temp, oil temp and GPS speedo. Added dummy led light, brake, turn signal lights. Custom molded into new oem cluster pod.
Title is in hand - clean and clear.
If you're looking at financing, check out Lightstream.com - awesome rates and deposit the cash same day. Doesn't matter on year/make/model, it's basically an unsecured loan with a low interest rate. I wouldn't bother unless your FICO is over 700 and you make a decent income.
$29,500
Located in Arizona
Model: 1993 Mazda Rx7 R1 (originally brilliant black) w/ 120k miles on body
Exterior Color: Lexus Stargazer Black Metallic (gold metallic flake in black paint)
Interior Color: Black
Engine/Drivetrain
6.0 Liter LS2 out of a Pontiac GTO (Less than 70,000 miles - pulled from GTO at ~42k)
T56 Pontiac GTO 6-speed tranny
Katech rod bolts
Improved racing oil pan baffle
LS7 flywheel + clutch
Hinson clutch master w/ remote bleed line
Hurst short-shifter w/ Steeda Tri-ax handle
Samberg subframe
Samberg transmission brace
Samberg V2 radiator w/ K&N Intake
Samberg bump steer correction kit
Samberg rear Cobra diff cradle
corvette pedestals
Professional Products Fuel Rails
Custom fuel lines using corvette FPR and OEM mounting provisions
Supra Denso Fuel pump
Spooling Performance Long-tube 1 7/8 headers
Custom stainless "Y" pipe: 2.5 inch per leg to 3.5 inch single exit exhaust
Custom 3.5 inch midpipe with Flo~pro resonator
OLD SCHOOL discontinued greddy 3.5 in, single-tip exhaust
All new gaskets installed when I installed the engine (e.g. rear main seal, oil pan, headers, etc.)
Cobra Rear
2003 Ford Cobra IRS diff. 3.55 gears w/ OEM carbon trac-loc LSD
Solid aluminum diff mounts
DSS axle bars
DSS aluminum drive shaft
Suspension
Tein Flex Coils
All suspension bushings replaced w/ Powerflex poly units
All pillow ball bushings replaced w/ OEM units
AWR Solid front say-bar mounts
OEM front/rear sways
Corner balanced by Darin at West End Alignment
Wheels/Brakes
SSR SP1 rims (SL disk IIRC), black face w/ polish lip
18x10 + 25 front, 18x11 + 8 rear
Hankook Ventus RS3 tires
Work lugs
Brembo slotted/drilled rotors
Stoptech pads
OEM calipers painted red
1" Mazda 929 Master cylinder
Interior
OEM R1 Suede Seats (no boltster tears)
Di-noc wrapped interior panels (can use re-wrap)
Redline leather wrapped trans tunnel cover
Redline leather shift boot
JDM Spirit R shift ****
Quad center gauge pod w/ Prosports (senders need replacing)
Nardi 350mm Deep Corn racing wheel w/ works Bell hub
Exterior
Lexus Stargazer black metallic (gold flake on black) - paint done by AutoExplosion
rear antenna shaved
hood nozzle holes shaved
99 spec OEM front end
99 spec lip
99 spec tails
"Rx7" vanity plate
Front pop-ups deactivated / removed (covers still in place)
**Headlights are in 99 spec turn signal housings - custom projectors w/ HIDs mounted in outer signal location, inner signal serves as both turn signal and daytime running lights
Shine OEM style 20mm wider front fenders
30 mm pulled rear fenders
Top fuel style rear wing
shine rear diffuser
shine feed style side skirts
MISC
Complete Halfspec A/C kit w/ condenser
Pez fan controller box
Pez power steering line
Dakota Digital SGI-5 speedo calibrator
Battery relocation to passenger side storage bin
Power
Tuned at CMS and dynoed 388 whp, 391 wtq without touching the engine
Plenty of room for growth with cam/heads/etc
Modifications since I purchased it in August 2014:
Maintenance Part Cost Part Ordered Status
Install Wiper Arms & Blades $80.00 9/28/14
Replace exterior/door Welt - Left $115.72 9/19/14
Replace Lock Cylinders / Rekey - Left $61.19 9/19/14 Completed 9/25/14
Replace Lock Cylinders / Rekey - Rght $61.37 9/19/14 Completed 9/25/14
Replace Transmission Mount $43.56 9/24/14 Completed 10/02/14
Service Differential $41.98 9/15/14 Completed 9/23/14
Replace Pinion Seal Differential $41.29 9/29/14 Completed 10/03/14
Replace Rear Axel Boots $56.86 9/15/14 Completed 9/23/14
Install High-Flow Cat $140.00 9/6/14 Completed 9/6/14
Lube Window Tracks / Clean $15.00 9/24/14 Completed 9/25/14
File ABS Mounting Location Right Rear $0.00 Completed 10/03/14
Remove/Replace Trans Mount $41.00 10/2/14 Completed 10/03/14
Brake Flush - Motul RBF600 $45.31 10/1/14 Completed 10/03/14
Oil Change - AMSOil ZROD $84.49 9/22/14 Completed 9/25/14
Transmission Flush - AMSOil TorqueDrive $58.48 9/22/14 Completed 9/25/14
Stereo Upgrade Part Cost Part Ordered Status
Amplifier Replacement $350.00 9/21/04 Completed 10/18/14
Front Speakers $150.00 9/22/14 Completed 10/18/14
Rear Speakers $150.00 9/22/14 Completed 9/25/14
Speaker Bracket Front $44.54 9/18/14 Completed 10/18/14
Re-wire speakers $40.00 Completed 9/25/14
Rear Subwoofer w/Custom Enclosure $513.68 9/28/14 Completed 10/18/14
Interior Clean-up Part Cost Part Ordered Status
Install Speedhut Gauges $1,573.87 9/18/14 Shipping 12/15/14
Remove/Replace Center Console Cover $80.19 9/17/14
Remove/Replace Center Console Plastic $90.44 9/19/14
Remove/Replace Door Plastic Left $286.40 9/19/14
Remove/Replace Door Plastics Right (with grip) $352.81 11/12/14
Remove/Replace A/C Panel $221.79 9/19/14
Replace Interior Door Seal - Left $82.56 9/19/14 Completed 9/28/14
Replace Interior Door Seal - Right $82.56 9/19/14 Completed 9/27/14
Replace Gauge Hood $373.16 9/19/14
Replace Door Sills $40.00 10/3/14 Completed 10/18/14
Install SakeBomb Passenger Grip $265.00 9/18/14 Completed 9/27/14
Replace Rear Plastics in hatch $270.00 9/28/14 Completed 10/18/14
Remove/Replace Defroster Vents $58.00 9/19/14
Remove/Replace Driver Window Switch $158.00 9/19/14
Remove/Replace Center Speaker Grill $50.95 9/19/14
Remove/Replace Rear Center Console $268.00 9/26/14
Misc Interior Screws $25.00 9/26/14
Misc Interior Plugs $25.00 9/26/14
Rear Seat Belt Bezel for Driver Side $25.00 9/28/14 Completed 10/18/14
Right Rear Quarter Panel / B-Pillar $125.00 10/3/14
Mirror Control Switch $75.00 10/3/14
Replaced RZ Seats with Factory R1 Seats $500.00 9/12/14 Completed 9/12/14
Hardware Upgrades Part Cost Part Ordered Status
Thermal Blocking Plate for MGW $80.00 9/20/14
Tremec #93 Offset Lever $93.39 9/20/14
Parts total (excluding labor) 7336.59
Note: New Cluster, Speedhut Gauges, A/C Panel and Center Console panel and Din Cubby are not pictured. They are all new (except the din pocket) and are being textured matched to custom gauge cluster. Hopefully I'll have pics from Broadfield on Sunday.
I have all panel covers, they're just not shown in this pic
Old Dec 13, 2014 | 04:11 PM
2swoosh's Avatar
2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future
nice toy there Dhalen how much power to the wheels?
Old Dec 13, 2014 | 08:16 PM
dhahlen's Avatar
Old Dec 15, 2014 | 06:05 AM
TurboRT's Avatar
TurboRT is infamous around these parts
Looks like a well-sorted LSx conversion and one of the few with A/C. Very nice. Do you have any higher quality pics, preferably outdoors with better lighting? Thanks.
Old Dec 15, 2014 | 11:20 AM
dhahlen's Avatar
A seem on the passenger side
Clear blemish on the roof (size of a dime)
After Idling for 25 minutes
Old Dec 17, 2014 | 01:06 PM
COBB Tuning's Avatar
COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !
Bump for a great guy! Car looks awesome!
-Mitch
Old Dec 17, 2014 | 08:22 PM
dhahlen's Avatar
Haven't received my cluster and gauges, yet. But it will be similar to this - red instead of yellow. With matching textured a/c and center panels.
Old Dec 20, 2014 | 01:51 AM
Enen's Avatar
Enen is infamous around these parts
Where are you located in AZ?
Old Dec 20, 2014 | 08:58 AM
dhahlen's Avatar
Originally Posted by enen
where are you located in az?
85323
Old Dec 23, 2014 | 06:27 PM
dhahlen's Avatar
Here is the cluster I ordered:
Old Dec 29, 2014 | 07:55 PM
dhahlen's Avatar
new a/c compressor ordered today
Old Jan 4, 2015 | 09:09 PM
dhahlen's Avatar
awdbiturbo1
Feb 18, 2016 10:24 AM
SharkyShark20
Sep 19, 2015 09:54 PM
Aug 21, 2015 06:34 AM
Gewgaw
Aug 19, 2015 11:52 PM
Nissan GTR
Aug 19, 2015 02:11 PM
