Well Sorted 2002 996 Turbo
Well Sorted 2002 996 Turbo 6spd
Year: 2002
Make: Porsche
Model: 911
Price: $47500
Mileage: 82000
Color: Black
Location (State): CO
Transmission: Manual
Drivetrain: 4WD & AWD
Car now has 82K + I am still driving it. So all upgrades have less then 5k on them. It is black with dark grey interior with factory aero kit and black powder coated wheels.
All major work and maintenance has been done by Cervelli Techinical Service and Black Canyon Performance. You can look online and see that this is the best p-car mechanic in the Southwest. They are familiar with the car if you have more questions about it. Just finished getting a complete detail, so sorry no tire kickers, we aren't driving it unless you have
cash in hand. All major problems and weak links from the 996 platform have been repaired and addressed on this car. No 2nd gear pop-out, slave cylinder, coolant lines, clutch, coolant tank,boost leaks,
etc. Everything is done and ready to enjoy.
Here is my list of "upgrades"
Big Brakes - 997 Turbo 350mm Slotted Brake Rotors and New OEM Pads - 200 miles ago. Also did brake fluid replacement with motul rfb. This upgrade is an amazing change in brake feel.
Fabspeed GT2 Exhaust with 100 cell cats - Stock one can be included if you need for emissions. Sounds awesome under W.O.T.
Cup Car Shifter Cables - 600 miles ago. $1200 upgrade to the factory mushy cable. Awesome feel, plus don't have to worry about the plastic ends failing like stock ones are known to do.
Cup Car Shifter - 600 miles ago. This is the best shifter available, all metal construction, no plastic bushings. Great feel with the matching cables.
Complete GT2 Slave Conversion with all factory parts. Drilled and tapped the transmission the correct way at Cervelli Tech Service to use all factory GT2 parts instead of aftermarket
brackets. They also modified the p/s pump to complete the install exactly like factory.
964RS Lightweight Flywheel
Sachs 2.5 Pressure Plate
GT3RS 4.0 Clutch Disk
Pioneer App Radio with Bluetooth and Hands Free Calling
Alacantra Wrapped Door Handles
Alacantra Wrapped Map Pockets
Alacantra Wrapped Center Console
SRM K24+ Turbos
SRM 4.5" Intercoolers
K&N Filters and Socks on Turbos
Mafless Markski 911tuning Custom Tune
72# Fuel Injectors
Threaded and Epoxied Coolant Lines
Tarrett GT3 Front Adjustable Sway
Tarrett GT3 Rear Adjustable Sway
LED Third Brake Light
New Fuel Filter
New Coolant Tank
Zip-Tied all Vac Lines
LLoyds Custom Floor Mats
New Tires
997 Coil Packs
New Plugs
Very quick and reliable car. Hate to see it go but I have too many cars and trying to sell a few of them to make room for something different. Serious
inquires only. Asking $47.5k
