2004 BMW M3 SilverGrey 6 Speed Subframe Reinforced
Old Oct 11, 2017 | 03:36 PM
Dotworks01's Avatar
Dotworks01 is infamous around these parts
Year: 2004
Make: BMW
Model: M3
Price: $26000
Mileage: 55380
Color: SilverGrey
Location (State): NY
Transmission: Manual
Drivetrain: Rear Wheel Drive
2004 BMW M3 Silver Grey/Black 6 speed with 55,380 Miles and Meticulously maintained. Equipped with cold weather package and sunroof. I am the third owner and the car has a clean Carfax with all original body panels intact. Car has always been garaged, and never driven in salt or snow. Car is in mint condition the exterior has no dents and all the panels are straight, the car has been professionally ceramic coated this year. Interior is extremely clean showing minimal wear and creasing. The OEM 19" Style 67s are in very good condition with no curb rash other than a 2" section on one of the fronts. Tires also all have good tread, and the brakes are in good shape and not needing replacement. This Car was never ran on a tight budget and has been cared for as it should.
This Car has had the Subframe professionally reinforced by TKX performance, and has also has upgraded Vanos bolts installed by previous owner. The car also has revised CPV O Ring. Car also has ECS tuning shock tower reinforcements, and Ground Control Rear Control arm reinforcements. The FCABS were replaced with OEM bushings as a preventative by previous owner.
Car for the majority is stock with the acceptation of these tasteful additions;
-PowerFlex Rear RTABS
-Turner Motorsports 4.10 Differential with Polished Ring and Pinion. This mod really woke a stock car up, and I do not regret it for one minute as drivability has not been compromised.
-Autosolutions Short Shift Kit
-ECS Tuning adjustable rear camber arms
-Hard motorsport RS style door pulls
-smoked marker lights
-Color Matched reflectors
-Bav Sound Soundplicity with XM, Auxiliary, and bluetooth capability. This brought this older car up to new spec.
-Ceramic Coated with IGL Coatings
-windows tinted suntek film 20% sides & 35% windshield
The Car has the following maintenance and preventative maintenance under my ownership;
-Inspections Done according to computer Intervals
-Valve Cover Gasket/ Vanos Gasket and Inspection of Vanos 45,900
-Brake Master Cylinder Sensor and Hood Switch Replaced
-4.10 diff Installed 45,900 by MNC performance
-Diff Oil Changed with OEM Fluid 47,500
-Oil Changed with TWS 47,500
-Engine Mounts Replaced precautionary 48,000
-CPV O Ring Replaced as precautionary 48,000
-Coolant Flush 48,000
-Oil Changed 52,300
-Air Filter Changed 53,000
Asking $26,000
Two Keys Included as well as stock camber arms and shifter
Located Long Island NY
Will trade toward 997 Turbo 6 Speed or Corvette ZR1
ID:	514224   Click image for larger version
ID:	514225   Click image for larger version
ID:	514226   Click image for larger version
ID:	514227   Click image for larger version
