FS: 996 / Boxster Parts (and 996' Cab Trade-in Info)
Originally Posted by tsweat
Hmm, I am thinking that it will not work. I pulled this out when I relocated the A/C down to the very bottom. If you could move your A/C controls up one spot (would have to buy a new trim piece -- it needs to be square), you could then use this below. Being a single molded piece, and tapered, I do not think there is anyway to make it fit into that spot above since it is square and this is more of a ummm, trapezoid? Make sense???
But hell, if you want it, I will sell it to ya (just not sure it will work for you)!
See how it angles down, i.e. the top is wider than the bottom. The 'slot' above the very bottom one is a regular rectangle so its corners make 90-degree angles, where this does not. Make sense?
I moved my A/C controls myself. It was fairly easy, moving just one location should not take you more than 30 minutes I would suppose.
I also have the 'squared' surround piece that you can have too. But without my car, I can not guarantee that it fits flush. This piece is from my A/C surround, but it is from the top and has a beveled edge. So not 100% sure its what you need. Regardless, the trim piece is cheap at the dealer.
Originally Posted by iLLM3
OHHHH i see it now, dammit i didn't see the angle of it, hmm! How big of a job is moving it up one spot, i couldnt imagine it being to hard lol. Sorry for the confusion!
The shelf alone is listed at $34 and change......
-Eli
tropicatango
Jun 8, 2025 01:00 PM
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
