FS: (Used car audio) JL Audio 450/4 & 500/1 & RE Audio 10" sub with sealed enclosure
Old Mar 28, 2009 | 07:51 PM
Dave I's Avatar
Dave I is infamous around these parts
JL Audio 450/4 amplifier:
$220 shipped.
Features
  • Channels 1 and 2:
    • Rated Power (stereo mode): 150W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
    • Rated Power (bridged mode): 300W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V)
  • Channels 3 and 4:
    • Rated Power (stereo mode): 75W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
    • Rated Power (bridged mode): 150W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V)
  • Peak Power Output 900 watts approx.
  • Differential-Balanced Input Topology: (2 pairs of inputs)
  • Channels 1 and 2 Crossover:
    • Fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
  • Channels 3 and 4 Crossover:
  • THD at Rated Power: <0.03% @ 4 ohm
  • S/N Ratio*: >108.5 dB below rated power
  • Frequency Response: 5 Hz-30 KHz (+0, -1dB)
  • Damping Factor: >200 @ 4 ohm per ch./50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Preamp Output: 2-channel (Pass-through with selectable input sourcing)
  • Bass EQ: +6 dB (variable boost up to +15 dB with Remote Bass Option)
  • Infrasonic Filter (Channels 1&2 only): defeatable 24dB/octave at 30 Hz
  • Speaker output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Fuse Rating: 60A
  • Dimensions: 13.4"L x 9.25"W x 2.36"H
Perfect working condition, cosmetically has some scratches on the top surface, nothing which would affect the performance of the amp...pics below.
JL Audio 500/1 amplifier:
$150 shipped.
500 watt mono subwoofer amp
Features
  • High-Damping Class D Circuit with discrete control circuitry (U.S. Patent #6,441,685)
  • Differential-Balanced Input Topology: 1 pair of inputs
  • On-board Crossover: Fully-variable (40-200 Hz), selectable-slope (12 or 24 dB per octave) LP
  • Preamp Output: 2-channel (independent active filter, parallel with amp filter or pass through)
  • Bass EQ: Single-band parametric with variable boost up to +15dB and Remote Bass Option
  • Infrasonic Filter: Fully-variable 24dB/octave from 15-60 Hz
  • Signal-Sensing Turn-On: Permits operation without remote lead
  • Dual mono speaker output connections: Accept up to 8 AWG wire
  • +12V and Ground connections: Accept up to 4 AWG wire
  • S/N Ratio: >95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
  • THD at Rated Power: <0.05% @ 4 ohm
  • Damping Factor: >500 @ 4 ohm / 50 Hz , >250 @ 2 ohm / 50 Hz
  • Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
  • Dimensions (L x W x H): 13.40 in. x 9.25 in. x 2.36 in. (340 mm x 235 mm x 60 mm)
Perfect working condition. Has fair amount of surface scratches on the top of the amp, which does not affect the performance. Also has a 1/2' x 1" chunk missing from one of the heat sink fins, when the amp was removed from my car by another individual. Can be repaired by JL for $75 according to customer service(see 4th pic below).
RE Audio 10" subwoofer with (approx) 1ft sealed enclosure. Equivalent to current SR Series:
http://www.reaudio.com/specs.html#sp_sr
Perfect working condition, $125 + actual shipping costs(as this thing weighs a lot).
Old Apr 6, 2009 | 09:36 AM
lovethesport's Avatar
lovethesport is infamous around these parts
how much will be shipping for 500/1 and box to toronto...L6R2K1
Old Apr 6, 2009 | 10:02 AM
mongrelcat's Avatar
mongrelcat is infamous around these parts
Interested in the 450/4, please PM me your email address. (Not enough posts to PM you yet.)
Old Apr 6, 2009 | 02:44 PM
Dave I's Avatar
Sorry guys, forgot to update this. All audio equipment has been sold.
Old Apr 6, 2009 | 03:00 PM
mongrelcat's Avatar
Bummer! Now where's the sad panda emoticon?
awdbiturbo1
Feb 18, 2016 10:24 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
