FS: OEM Porsche 996TT brake kit...Brembo Calipers, Rotors, Pads...Complete!!!!
Old Feb 14, 2010 | 10:12 PM
ZIP22's Avatar
ZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond repute
Category: Brakes
Price: $0
Part fits: Porsche 911 996 Turbo, Porsche 911 996 Non-Turbo
Location (State): CA
Porsche OEM 330 MM Brake Kit - Front and Rear
Providing massive amounts of braking power for wide-body cars, this kit will impress on the street or track. Using factory parts, you can upgrade to the Porsche 4-Piston front and rear brake system that is found on the 996 Turbo. The rotor size size is increased, to 330mm. This kit comes complete with front pads, rotors, red calipers, mounting hardware. All parts are OEM Porsche Parts.
Over 75% brake and rotor life left...see picts...parts must go!!!!
$old !!!!
330mm compared to 350mm
Old Feb 14, 2010 | 11:43 PM
wutanggwang's Avatar
wutanggwang is a jewel in the roughwutanggwang is a jewel in the roughwutanggwang is a jewel in the roughwutanggwang is a jewel in the rough
Do you know if these will fit on a 993 widebody? Thanks
Old Feb 15, 2010 | 04:55 AM
ZIP22's Avatar
Hmmm...not sure.
Old Feb 16, 2010 | 08:50 PM
ZIP22's Avatar
UP....still for sale! :-)
Old Feb 16, 2010 | 09:20 PM
01P996C2's Avatar
01P996C2 is infamous around these parts
Any issue on fitment for 996 c2 narrow body? What type pads are in and have rotors been turned yet? Thanks you can PM me I may be able to return but have limited posts. Thanks tom.
Old Feb 24, 2010 | 06:24 PM
ZIP22's Avatar
Not sure on the fitment but with spacers it should be a non issue but check with a Porsche tech first. The pads are stock and the rotors have not been turned.
Old Feb 24, 2010 | 06:25 PM
ZIP22's Avatar
Price updated and lowered...these must go! :-)
Old Feb 25, 2010 | 04:18 PM
tarzancoe's Avatar
tarzancoe is infamous around these parts
I checked. They will not fit a 99 C2. Bummer.
Old Feb 25, 2010 | 05:15 PM
airedale's Avatar
airedale is infamous around these parts
1999 c4 ?
Will these fit a 1999 C4 with 18" wheels?
Old Feb 25, 2010 | 09:32 PM
ZIP22's Avatar
You may need spacers....but please check with with a local pcar tech.
Old Feb 26, 2010 | 11:11 AM
Purplxd's Avatar
Purplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud of
You can make them fit a C2.... I did it.
http://emeraldapple.wordpress.com/
Cheers
Aaron
Old Feb 26, 2010 | 11:37 AM
airedale's Avatar
Looks like you would know.
I'm thinking of using these on my 1999 C4 Tip.
The stock brakes are the black ones and I can use them on another car.
But, it looks to me that these would be plug and play on my Porsche.
I have the 18" factory wheels with all the cap head bolts and they would clear these rotors?
What is the opinion out there?
Will this upgrade work? Is it a good idea?
Thanks.
Old Feb 26, 2010 | 01:02 PM
Purplxd's Avatar
I am pretty sure the 996TT came with 18" so I don't see why not. The only issue is your wheel carriers may not be the same (which I don't think they are) and the bolt holes won't line up.
You'd need to change to TT wheel carriers and possibly struts, not sure if the C4 has the angled strut install to clear the front axles as the TT does... I'd assume so, but I'd need to compare to confirm.
Cheers
Aaron
Old Feb 26, 2010 | 03:02 PM
BartN (TX)'s Avatar
BartN (TX) has a spectacular aura aboutBartN (TX) has a spectacular aura about
This is a steal. For all of you TT guys who's brakes have discolored from track use these would be a perfect fix. Better than repainting your current calipers.
GLWS!
Old Feb 26, 2010 | 03:40 PM
P Diddy's Avatar
P Diddy is a glorious beacon of lightP Diddy is a glorious beacon of lightP Diddy is a glorious beacon of lightP Diddy is a glorious beacon of lightP Diddy is a glorious beacon of light
bump for a good price.
