X51 Oil Pan & Deep Sump Oil Spacer
Old Mar 11, 2010 | 07:59 PM
mobonic's Avatar
mobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud of
Category: Accessories
Price: $499
Part fits: Porsche 911 997 Non-Turbo, Porsche 911 996 Non-Turbo
Location (State): AL
Item Condition: Brand New
Both items are brand new! Only opened!
The X51 baffle has already been trimmed by Suncoast.. so just pop in!
1. Porsche OEM X51 Oil Pan with Baffles
The X51 oil pan helps keep your oil near the pump during hard turns. As the oil moves from one side to the other, the baffles will close keeping the oil where it is supposed to be. This can prevent significant engine damage from a lack of oil, oil starvation is still possible, but the risk is reduced significantly.
This product is great for track usage!
Fitment:
Carrera 2 or 4 (996) - 1999-2004
With modifications, this can be used on 997 (2005-08), Cayman, and Boxster applications. Contact us for a template to trim the upright metal bracket.
2. LN Engineering Deep Sump Oil Pan Spacer
Scavenging and aeration in the oil pan have been identified as a problem in 996 and Boxster models experiencing high G-forces on the racetrack. The R-9095 oil pan spacer provides a simple solution. This spacer increases sump capacity by half a quart, providing more reserve to ward off starvation.
The R-9095 kit clears all factory options including the rear skid plate. Added oil capacities as well as increased oil pan surface area increase oil cooling and engine performance.
Material: 6061 T6 Aluminum Alloy
Finish: Clear Anodized
Weight: N/A
Models: Boxster, Boxster S, and 996 models (excludes GT3 and turbocharged models)
Installation: For best results internal baffle passages should be modified. Modification instructions included in the kit.
Miscellaneous: Spacer adds .5 U.S. quarts to oil pan volume and improves internal baffling system. Extension bolts included in the kit.
Update: the R-9095 has been approved by the Porsche Club of America for use in PCA club racing Stock and Prepared class cars
Old Mar 12, 2010 | 06:48 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
PM sent on X51 baffle
Old Aug 24, 2010 | 07:11 AM
ApexL8's Avatar
ApexL8 is infamous around these parts
Is the LN Engineering Deep Sump Oil Pan Spacer still available? I would PM you, but my post count is so low I am unable to.
Cheers,
Chuck
Old Aug 24, 2010 | 08:46 AM
mobonic's Avatar
yes still available
Old Aug 24, 2010 | 09:06 AM
ApexL8's Avatar
Are you willing to split up the pan and spacer? You can email me at {address removed after posting}. Thanks, Chuck
Old Mar 22, 2011 | 12:56 PM
Dan Newton's Avatar
Dan Newton is infamous around these parts
If you still have your X51 sump set up, please give me a call at 484-744-1492. Thanks Dan.
oo7
Sep 10, 2015 08:08 AM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
m_motorsport
Sep 2, 2015 12:53 PM
