F/S AP rear sway links 996TT/996
Old May 24, 2011 | 05:51 PM
Turbohead's Avatar
Turbohead is just really niceTurbohead is just really niceTurbohead is just really niceTurbohead is just really nice
A brand new, never opened set of rear sway bar links from Agency Power. These list for $220. Fit 99-05 996 C2, C4 and TT. Here is the link to the Agency Power website:
http://www.agency-power.com/catalog/...mqu18njrkpskv3
$175 shipped in the US.
With performance handling in mind, Agency Power has released their all new Performance Rear Sway Bar Links for the Porsche 996 Carrera 2 and 4.
Why sway bar links? The factory sway bar links utilize a simple design, ball joint and thin connecting rod. This style of links can be found on several makes and models of different vehicles. However, for the purist, the hardcore driver, and the weekend racer, these factory links are not enough. One of the first performance modifications you make in handling is the sway bars to assist with over and under steer. During aggressive driving scenarios, these factory links will flex and create a non rigid feeling. The Agency Power Rear Sway Bar Links for the Porsche 996 will change this immensely.
These rear end links are made of high grade 6061 CNC machined aluminum. The link maintains the same thickness throughout the length giving it a very strong structural integrity. The spherical bearings (monoballs) are used instead of urethane bushings for longevity as well as reduced noise. The bearings are sealed to prevent from wear and tear caused by dirt, water, mud, etc. Each bearing is held in place with a C clip to allow easy maintenance if desired. All hardware is stainless steel to prevent from rust and long term corrosion. The stainless metal collars are designed to give the link the correct alignment when attached to the shock body and sway bar. Each bolt uses an allen head for easy installation. Finally, the Agency Power Porsche Sway Bar Links are anodized in Royal Blue and engraved with the stylish AP logo. Not only standing out in your rear suspension setup, but offering you an edition that will truly enhance your handling performance.
Fits: Porsche 996 C2, C4 99-04 and 996 TT 01-05.
Old May 24, 2011 | 05:59 PM
bbywu's Avatar
moved to appropriate forum
Old Jun 2, 2011 | 05:08 PM
Turbohead's Avatar
Thanks for the move ..now I hope some buys them
Elliot
Old Mar 5, 2012 | 01:18 PM
100plus's Avatar
100plus is infamous around these parts
Still for sale?
Old Mar 5, 2012 | 07:07 PM
Turbohead's Avatar
Sold along time ago
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
