USED - APR R1 Diverter Valve
Category: Accessories
Price: $200
Private or Vendor Listing: Vendor Listing
Part fits: Porsche 911 997 Turbo, Porsche 911 996 Turbo
Location (State): FL
DVs have been SOLD - Thanks 6Speed!
These units are used and come as seen in the attached image. There is cosmetic wear on the valves but functionality is 100%. Here is some more information on the R1 DV:
Highlights of the APR R1 Diverter Valve Include:
- Diaphragm-Based Valve
- High-Temperature, Nomex-Reinforced Material for Extreme Durability
- Zero-Friction
- No Sticky O-Rings to Maintain and Grease
- No Pistons to get Stuck
- Consistent Performance Year Round
- Flow-Optimized, Investment-Cast Main Housing
- Stainless Steel Vacuum Fitting
- Zero-Maintenance Design
- Built with Finest Materials and Surface Treatments
- Fully Machined and Assembled at APR Headquarters in the United States for Optimal Quality Control
The APR R1 diverter valve was designed to be the ultimate solution to the problem of unreliable factory and aftermarket diverter valves and to be the leader in performance. Although most are of good design, factory diverter valves are built in a very conscious manner and the materials and overall life and reliability suffer. For the performance enthusiast, the diverter valve is an important component whose proper operation is paramount to optimal engine operation.
Enter the R1: APR's R1 diverter valve addresses all of the reliability problems of the factory-supplied diverter valves and aftermarket replacements and takes performance to the next level. The R1 is a diaphragm-based valve. A diaphragm is the best option for a diverter valve for several reasons. First off, a diaphragm has negligible friction. Piston-based valves have considerable friction from the piston, o-ring, and bore assembly. The lower friction R1 diaphragm equates to faster response and better overall performance. Secondly, diaphragms do not require the periodic greasing that piston-based valves do. Piston-based valves must be qreased periodically (usually every year or sooner), requiring removing the valve from the car, disassembling and reassembling the valve. The APR R1 was designed to be maintenance free for the life of the product. Thirdly, a diaphragm based valve will never have a stuck piston. Piston-based valves periodically incur stuck pistons (especially if the required maintenance schedules are not followed.) Due to the lack of a piston, the APR R1 solves this problem.
The R1 is designed for optimal performance. The main body of the valve is investment cast in an aluminum alloy. By utilizing this casting process in lieu of a more conventional machining process, APR was able to optimize the internal geometry of the valve to provide the ultimate in flow performance. This geometry cannot be created utilizing conventional machining. As such, the APR R1 has much better flow characteristics than other diverter valves. Combined with the low friction diaphragm assembly, this equates to a valve that is truly a performance leader.
The materials used in the R1 are standard setting. The diaphragm is created out of high temperature material and incorporates a Nomex fabric reinforcement layer for enhanced durability and a diaphragm that will never tear. The alloy main body is finish machined at APR and receives a multilayer corrosion resistant and cosmetic enhancing finish. All machining and final assembly takes place at APR headquarters in the United States for optimal quality control and consistency.
Thank you for looking,
If you have any questions?
Email: phil@uspmotorsports.com
Phone: (888) 755-7772
or PM me!!
sdg1871
Nov 22, 2015 07:27 PM
