Lamborghini Gallardo LP560, LP570 and Audi R8 2009-2014 Carbon Ceramic Brake CCB Kit
Category: Brakes
Price: $7495
Part fits: Lamborghini, Other
Location (State): FL
All four rotors swapped to Carbon Ceramic Brakes (CCB) will be 50lbs of rotating weight lost which is absolutely HUGE! This rotating weight loss is like losing 3x times that weight from the car. This will brake better, ride smoother as its less work for the suspension, turn better, respond faster in turns, better gas mileage, and even make the car accelerate faster.
These are Carbon Ceramic Rotor Discs from the latest Brembo generation which were USED for a brief time and show slight wear on them in excellent condition.
FRONT Carbon Ceramic Brembo Brake Kit Specifications-
Custom Billet Aluminum hats were made using OEM Brembo mounting hardware and are now anodized Black for a cleaner OEM appearance. These rotors and hats weigh 11lbs fully assembled which is far lighter than almost any other Carbon Ceramic rotor out there because of the billet aluminum center hats. Factory Steel rotors are approx 28lbs each, so by swapping these rotors alone, you save 34lbs with just the front pair of rotors in rotating weight. That is a lot of weight you can feel the difference with!
They are made to bolt on to the FRONT of any 2004-2014 Lamborghini Gallardo, LP560, LP570, and all Audi R8 years that came with Steel rotors. This will convert your steel equipped rotors to Carbon Ceramic rotors using all OEM parts (calipers, pads, lines,) without removing or opening ANY brake lines.
These rotors are 380mm which are much bigger than OEM and use billet aluminum spacers to space out the OEM Brembo 8 piston brake calipers. They use an OEM Lamborghini pad size, nothing changes there. You literally unbolt the rotor, install the billet aluminum spacers, and bolt them back on without touching anything else.
You can use the OEM brake pads or any other brake pad that is made for the stock brakes BUT I would highly recommend you purchase a ceramic based brake pad such as a PAGID pad which will allow you to take advantage of the tremendous braking power!
OEM Front Steel Brake Specifications: 365mm x 34mm weigh approx. 28lbs each
Our Front Custom Carbon Ceramic Brake Specifications: 380mm x 34mm weight approx. 11lbs each
Front rotor savings= 17lbs x 2= 34lbs of rotor weight savings
While changing front and rear to CCB is the best way to go for MAXIMUM weight savings, it is not necessary to change the rear brake rotors of the car to CCB as we have tested 200mph with CCB up front and OEM steel in the rear. If you just want a pair of front CCB Brake rotor upgrades, please check my other auctions.
REAR Carbon Ceramic Brembo Brake Kit Specifications-
I have only 1 pair of rear Carbon Ceramic rotors that fit several cars listed below that had this as a factory option. These rotors are also interchangeable with non CCB cars as they literally just swap out the steel disc to this and save nearly 50% of the rotating weight.
Once I sell this COMPLETE kit, I will only have the custom FRONT CCB rotor kit available so first come first serve.
2009 Lamborghini LP560-4
2010 Lamborghini LP560-4
2011 Lamborghini LP560-4
2012 Lamborghini LP560-4
2013 Lamborghini LP560-4
2014 Lamborghini LP560-4
2010 Lamborghini LP570-4
2011 Lamborghini LP570-4
2012 Lamborghini LP570-4
2013-Lamborghini LP570-4
2014-Lamborghini LP570-4
All variations of the LP550 as well.
2015+ Lamborghini Huracan 610-4
2009 Audi R8
2010 Audi R8
2011 Audi R8
2012 Audi R8
2013 Audi R8
2014 Audi R8
OEM CCB Part # 420615601L -Rear Left Rotor
OEM CCB Part # 420615602F -Rear Right Rotor
OEM Rear Steel Brake Specifications:356mm x 32mm weigh 20lbs each
OEM Rear CCB Brake Specifications: 356mm x 32mm weigh 12lbs each
Rear rotor savings= 8lbs x 2= 16lbs of rotor weight savings
PRICE: $7495 FREE SHIPPING IN THE USA
Kai@ELITEMS
Lamborghini
Feb 24, 2015 11:32 AM
Dan@SCB
Oct 16, 2013 07:38 AM
