996tt upper strut mounts
Old Feb 12, 2018 | 03:15 AM
bushrat's Avatar
bushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond repute
Looking for a good takeoff set of upper strut mounts for my 2004 996 turbo X50 cab
Old Feb 12, 2018 | 06:25 AM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
had mine replaced. They used an aftermarket set, but they were beefier. Cannot remember the brand.
Old Feb 12, 2018 | 09:25 AM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
PM sent.
Old Feb 12, 2018 | 09:39 AM
Slider's Avatar
Elephant Racing makes the best set for adjustability - roughly 3 times OEM. I finally have a good alignment.
Old Feb 12, 2018 | 10:10 AM
bushrat's Avatar
strut mounts
Which ones did you install
Old Feb 12, 2018 | 10:55 AM
jdexter's Avatar
jdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to behold
I have a whole set of low miles OEM suspension if you want a refresh...
Old Feb 12, 2018 | 11:18 AM
bushrat's Avatar
Strut mounts
What shape are the strut mounts in, miles on them? 55000 miles on mine and they are shot. Considering going new unless I can find a really low mile used set. Prices on these are rather steep but don't want to be doing this job twice. Will PM you my email address if you care to forward photos. Thank you for your response.
Old Feb 12, 2018 | 11:26 AM
bushrat's Avatar
elephant strut mounts
Think I found the ones you installed. Look like a monoball unit, do you experience additional cab noise opposing these to a rubber insulated stock part. Trying to make a decision which way to go.
Old Feb 12, 2018 | 11:58 AM
Slider's Avatar
They only make one that fits 996 TT: here
I didn't experience any extra noise at all. I had switched to the Tarrett first, but they were not properly designed for installation with OEM shocks (which I had at the time).
Old Feb 12, 2018 | 12:03 PM
bushrat's Avatar
You have these installed with the PSS10 struts and are quite happy with them ? Much of a difference over stock rubber bushed units?
Old Feb 12, 2018 | 01:00 PM
Slider's Avatar
My OEM strut mounts were worn and quite squeaky. New camber plates stopped the squeak right away. The PSS10s fixed any play in the damping system. I can totally ignore speed humps now with absolutely no dive after the hump but no hash impact either - hard to believe that is possible. Performance-wise very stable in high-speed corners. Absolutely happy with the result.
Old Feb 12, 2018 | 01:46 PM
bushrat's Avatar
Strut mount bushings are cracked, shocks are worn out as well. Imagine I will see quite a difference when everything back together. Pricey though.
Old Feb 12, 2018 | 02:16 PM
Slider's Avatar
Yes, very pricey... I kept waiting for a "special" - never happened...
Charsiu
Jul 9, 2013 03:09 PM
Reborn996
Sep 9, 2012 07:26 PM
@l996
May 12, 2011 02:34 PM
utkinpol
Dec 23, 2009 01:36 PM
Greyghost
Jan 12, 2005 05:11 PM
