3.4L 06-08 987 Porsche Cayman S Engine Complete (VIN code B) FRESH BREAK IN ONLY
Old May 24, 2018 | 04:53 PM
jordonmusser's Avatar
jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !
Category: Engine - Complete Motors
Price: $10000
Part fits: Porsche Boxter/Cayman
Location (State): TX
Engine has only about 200 break in miles on it. Removing it to do an LS3 Swap. Gearbox is also available (see other auction). If you are local you are welcome to come by and see it run. I will pull and ship in 2 days of close of auction.
Recently passed Texas emissions and safety inspection. Engine has the following upgrades: Nickel silicon plated cylinders, recoated pistons, pinned and inspected intermediate shaft, replaceable ceramic intermediate shaft bearing (from LN engineering, dual row ceramic bearing with spacer so that the bearing can be replaced without taking the engine apart if desired by a future owner), ARP connecting rod bolts (one of the areas where Cayman S models driven on a track tend to fail). The following new parts were also installed during the engine assembly, main bearings, rod bearings, wrist pin clips, Goetze piston rings, timing chains, timing chain guides, timing chain tensioners, cylinder head bolts, crank carrier bolts, head gaskets, crank seals, valve seals, and most other seals, air oil separator, clutch actuating cylinder, flywheel pilot bearing, and forward engine mount bushing.
I have videos posted on YouTube of the engine running and driving. Contact me.
Freight charges will be whatever the actual costs are, I will contact you for options
ID:	526504   Click image for larger version
ID:	526505   Click image for larger version
ID:	526535   Click image for larger version
Old May 24, 2018 | 10:53 PM
GT3 Chuck's Avatar
Administrator
Please post the required actual item photos...thanks
Old May 25, 2018 | 07:28 AM
doh, it is still in the car so somebody can come drive it if they want before purchase. This is the actual car the actual engine is in...
Old May 25, 2018 | 11:55 AM
GT3 Chuck's Avatar
Administrator
I know there isn’t much to see from the top and you really should get it on a lift but you need to provide something that shows what you are actually selling...you aren’t selling the complete car.
Old May 25, 2018 | 11:57 AM
Copy! Ill get on it. thanks.
t0mkat
Jun 16, 2016 05:33 PM
limitlas
Jun 23, 2015 09:39 AM
hydeaway
Nov 12, 2007 05:34 PM
