FS: Bentley Battery Trickle Charger Tender Maintainer US7002 CTEK
Old Jul 6, 2018 | 01:25 AM
Buddy123's Avatar
Buddy123 is infamous around these parts
Category: Engine - Electrical
Price: $275
Part fits: Bentley
Location (State): NJ
Up for sale is a Bentley CTEK OEM battery Tender/trickle charger.
This item fits Bentley Continental GT, CGT, Flying Spur, Mulsanne 2012-17 Battery Trickle Charger Tender Maintainer US7002 CTEK, lightly used in great conditions both physically and functionally. All mechanics work perfectly, comes with carrying case embroidered with the Bentley Logo. Inside are the instructions as well.
Circular 12v Type Connection, please see pics. Pics are of actual item you are purchasing. Reminder there are two types of connectors, Circular and Cylinder. This is for the Circular models. Please consult the owners manual to verify the correct one.
Asking $275.00 USD please pm me for more info.Below are some questions and answers I’ve found that may be helpful. Please check with your local Bentley dealer that this product will fit your car.
Q: If I have 2 batteries (Bentley GT), does it charge only the one it is hooked to, if using cigarette lighter charger does it only charge one or both.A: It will handle two batteries okay. whether it will charge both or only the one it is connected to depends entirely on how you batteries and electrical system are wired.
A: Your Bentley likely has a battery isolator, as well as some sensitive battery management devices. To charge both batteries properly you will need to find the isolator input, the easiest place is probably the alternator + terminal or the jump-start terminals. I would recommend contacting you dealers service department and see what they can tell you. Short answer; no, I would not charge it through the cigarette lighter outlet.
A: The "cigarette lighter" style port in the trunk near the passengers side battery in the boot(trunk), is setup to handle both start and run batteries. There is a lead(sm. yellow wire) from the terminal which bypasses the battery switching relay. Connecting directly to terminals will only charge one or the other and can leave you stranded. Continental flying spur is my current application and working well.
ID:	528321   Click image for larger version
ID:	528322   Click image for larger version
ID:	528323   Click image for larger version
ID:	528324   Click image for larger version
ID:	528326   Click image for larger version
ID:	528327   Click image for larger version
ID:	528328   Click image for larger version
ID:	528329   Click image for larger version
gray911
Sep 11, 2017 07:36 PM
dan_189
May 11, 2015 01:34 AM
boochook
Jun 7, 2013 02:02 PM
farfel
Feb 8, 2012 09:24 AM
ThunderRolls
May 12, 2010 08:37 PM
