996/997TT Track Part Out! Must See!
Old May 6, 2019 | 10:25 PM
calavi's Avatar
calavi is infamous around these parts
Category: Accessories
Price: $2500
Location (State): AL
Sold My Porsche 996 Turbo S and bought a 991 GT3. These parts do not fit my current setup, boy do I wish they did. All these part have about 3,000 miles and 2 Track events, as I did not drive the car much in the past 2 years of ownership.
$1400 Fits 996 & 997, The BBi Street Cup Porsche 996 & 997 Street Cup Harness Bar ( With Custom RSR Cup Gussets} . features a 2 piece design and high strength seamless tubing (1.5” x .120” main hoop & 1.5” x 0.95” rear hoops) for excellent strength to weight ratio. With our sensible approach, the 2 piece design allows the bar to be mounted to the front seat belt mounts and to the rear strut towers (stronger mounting points), and still be compatible with the factory Bose subwoofer. Other similar roll bars on the market are not compatible with the subwoofer. For superior strength and rigidity, the bar utilizes “X” braces on both front and rear sections and each joint has been meticulously TIG welded by hand. Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit. These unique joints allow us to eliminate the more traditional slip fit tubes with an unsightly through-bolt and nut. Paid Over $3,000+ Brand new
$180 Shipped, Tarret Drop Link (pr), Front, 996/997 Fits KW Coilover -PSS9-10
$1000 Shipped 996/997 ERP Cup-Series Control Arm Kit, comes with tarret for your Porsche. Much more than just another billet replica of the GT3 arm; this design is superior to any other aluminum arm on the market. For safety, the problematic 12mm ball joint design, used on both OEM and other aftermarket arms, has been completely redesigned for a foolproof, larger, significantly stronger. Solid thrust arm bushings and sealed monoball inner ends are used to eliminate the spongy rubber OEM bushings and provide a precision ride for improved feedback, steering response, and overall handling. Both are CNC machined from 6061-T6 aluminum alloy and are anodized red for corrosion resistant and attractive finish. The solid thrust arm bushing is adjustable for increasing or decreasing wheelbase and adjustable caster. Camber and track width can be accurately and repeatedly adjusted with precision GT3 style shims. A competition proven design that allows for up to 20mm of adjustment per side and up to an additional 2 degrees of negative camber. [ Comes with [SPOILER] Litronic Bracket, 10mm, 4mm, 2mm Shims for lots of different camber setups]
$350 Shipped 996/997 TarretRear Toe Control Arm with Locking Plate Kit..The factory control arm can’t compensate enough when lowering your 996/997/986/987, leaving you stuck with as much as ½” of toe in. The result is poor handling and rapid tire wear. This kit will provide the additional adjustment needed.
$600 Shipped DNN 992 with sirius XM With all cable conversion and 996 faceplates, Add $400 with alpine amp and all required cables for the install. [996 only]
$100 Shipped Porsche 996 GT3 Front brake ducts [Brand New]
SOLD Shipped 2 bottles of Brand New Motul Brake fluid
$20 Shipped each- Brake drain valves
$350 Shipped 996 TURBO EVOLUTION MOTORSPORTS V-FLOW AIR INTAKE SYSTEM
http://www.evoms.com/EVOMS_996TT_and...tkvf996xxx.htm
Evolution MotorSports V-Flow Air Induction Systems are computer-aided designed specifically for each individual application to give your engine maximum air flow, which means more horsepower, torque and improved performance. All V-Flow air intake systems have been dyno tested and tuned to provide maximum performance and efficiency. By utilizing computer-aided design, EVOMS designers produced the 996TT / GT2 air intake system to provide an unmatched fit, finish and superior air filtration. New since 2010 and on is the implementation of our exclusive 100% oil-free “Synthamax” air filter technology. Our fully synthetic filter technology provides optimized flow with unmatched filtering properties which equals maximum power and protection.
Features:
  • Increases Power and Torque
    • HP Gain: ~15 HP*
    • TQ Gain: ~15 TQ*
  • Improves Turbo Boost Response
  • Installs in the Factory Location - No Modifications Required
  • Utilizes the OEM “Ram Air” Fresh Air Duct for Lower Air Intake Temperatures
Call or text Casey- (714) 473-4427
Old May 7, 2019 | 03:42 AM
jcm3's Avatar
jcm3 has much to be proud ofjcm3 has much to be proud ofjcm3 has much to be proud ofjcm3 has much to be proud ofjcm3 has much to be proud ofjcm3 has much to be proud ofjcm3 has much to be proud ofjcm3 has much to be proud of
Want the engine mounts..pmd
Old May 7, 2019 | 05:31 AM
nautique1980's Avatar
nautique1980 has much to be proud ofnautique1980 has much to be proud ofnautique1980 has much to be proud ofnautique1980 has much to be proud ofnautique1980 has much to be proud ofnautique1980 has much to be proud ofnautique1980 has much to be proud ofnautique1980 has much to be proud of
I’ll take the coilovers @ $2,500. Also interested in exhaust an have a few questions. My number is+18162008193 if you don’t mind text it will certainly expedite on my end. Thank you!
Old May 7, 2019 | 05:33 AM
CBRacerX's Avatar
CBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to behold
Does that Kenwood support Apple CarPlay?
Old May 7, 2019 | 12:45 PM
calavi's Avatar
No this model does not support apple car play. But calling and playing through Bluetooth is just as simple. It does come with 996 CAI install kit for my kenwood. So install should be a breeze. https://cai-store.com/pages/911-boxster-double-din-conversion
Old May 9, 2019 | 09:41 AM
trillypop's Avatar
trillypop is infamous around these parts
Sent you a text regarding the seats and harnesses.
Old May 9, 2019 | 11:23 AM
pca7ggr's Avatar
5 Year Member
pca7ggr is infamous around these parts
Brake fluid
I’ll take it.
Old May 14, 2019 | 02:46 AM
996pp's Avatar
996pp is infamous around these parts
By any chance do you have aftermarket intercoolers? Or 997.2TTS Intercoolers?
Old Jun 4, 2019 | 12:52 PM
calavi's Avatar
bump
Old Jul 15, 2019 | 11:03 AM
AMGo's Avatar
AMGo is infamous around these parts
Originally Posted by calavi
bump
i Sent you a PM on the Harness/Roll Bar.
Old Jul 22, 2019 | 08:34 PM
jcc0016's Avatar
5 Year Member
jcc0016 is infamous around these parts
Are the front drop links still for sale? Thanks
Old Jul 22, 2019 | 11:58 PM
bushrat's Avatar
bushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond repute
price on stainless braid brake lines..... mail to BC Canada?
Old Aug 1, 2019 | 11:11 PM
capnnard's Avatar
capnnard is infamous around these parts
PM sent on suspension parts
Old Aug 2, 2019 | 12:42 AM
Rvpps2rocks's Avatar
Rvpps2rocks is infamous around these parts
Pm sent
Old Oct 30, 2019 | 05:53 PM
Bob Z.'s Avatar
Bob Z. is just really niceBob Z. is just really niceBob Z. is just really niceBob Z. is just really nice
I have a bud looking for takeoff PCCBs, 991.2 - PM me if you have something!
