Girodisc 380mm Front Rotor Hats for Porsche 997 Turbo w/PCCBs
Old Mar 4, 2021 | 01:02 AM
mavila's Avatar
mavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of light
Category: Brakes
Price: $295
Location (State): CA
I am selling a pair of 380mm Girodisc rotor hats for the front brakes for a 997 turbo equipped with PCCB rotors. These are just the hats - no rings. You can easily buy a new set of replacement rings directly from Girodisc. These would be $650 new from Girodisc. Feel free to PM with questions or for additional pictures. SOLD!
From the Girodisc website:
"The Girodisc system is a direct replacement for the OE disc on all 997 Turbos with OEM PCCB rotors. No modifications are necessary, allows use of factory unmodified pads unlike most aftermarket solutions for this application. The disc will bolt directly to the car and work with OE calipers perfectly. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency.
The central hat section of our rotor is made from strictly U.S. sourced 6061-T6 aircraft specification aluminum. The disc is made from our own proprietary cast iron, poured in the USA and machined from start to finish in house at Girodisc. The rotor utilizes a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 12 high strength alloy steel drive pins, manufactured by Girodisc in the USA to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. The pins are secured by class 12.9 cap screws with hardened washers. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Once the Girodisc system is in place, simply replace the cast iron rotor when needed.
When used with performance pads and hi-temp fluid, you have what amounts to a truly amazing solution to overheating or warping rotors."
Old Mar 4, 2021 | 01:53 PM
JCD911S's Avatar
JCD911S is just really niceJCD911S is just really niceJCD911S is just really niceJCD911S is just really nice
Interested. PM sent.
Old Mar 4, 2021 | 07:19 PM
mavila's Avatar
sold!
GT3/GT2/GT Vendor Classifieds
Jul 3, 2012 06:28 PM
Chris Green@USP
Audi
Mar 24, 2012 02:48 PM
