difference between CGT 06' and 07'?
Old Jan 14, 2009 | 04:34 PM
blitzo's Avatar
blitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to behold
Smile difference between CGT 06' and 07'?
What is the difference between the CGT 06' and 07'? Does anyone know?
I am looking at buying a used CGT in the next 30 days as a daily driver. 07' seems a little more expensive than my budget but the 06' warrant is about up.
Are extended warranties on CGTs expensive for an 06' or 07'?
Are there any other 4 seater coupes that you would recommend in the same price range? was also considering a db9, or a ferrari 612 (if i could find one in my price range)
thnx
Old Jan 23, 2009 | 12:41 AM
unpollo2's Avatar
unpollo2 is infamous around these parts
Main difference is the nav system switched to Dvd from CD... So less discs to swap and more street names displayed onscreen. I believe the search engine is better as well.
Rear view camera also an option but I thought that was just on 08s
Extended warranty run $3000 per year up to 2 years but you cant get it unless you buy the car from Bentley dealer. New rules to differentiate price from all those 05 and 06 being traded like bad stocks.
Old Jan 23, 2009 | 12:45 AM
unpollo2's Avatar
I also looked at DB9
No back seats. No trunk space. Low seat position. Low ground clearance (you will be bottoming the front end alot). Less power.
Positives? It's better looking than the CGT.
Old Feb 7, 2009 | 07:03 PM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
the CGT worth 100 time more than the DB9
Blue Chip
Sep 10, 2015 07:07 AM
falter
964 Turbo
Sep 4, 2015 01:37 PM
