Bentley GT owners, question about possible warning light?
Old Feb 1, 2013 | 01:16 AM
Nixon Marx's Avatar
Nixon Marx is infamous around these parts
Hello,
I got the very same problem this morning, for some unknown reason; I never use p-brake; I drive the car maybe twice a month; it's a 2006 conti gt mulliner. Moreover another problem suddenly came on at the same time, automatic lights didn't work anymore; So far it seems related to electronic momre than mechanic; I'll have the car inspected by Bentley Brussels and will keep you posted;
best regards,
Nixx
Old Feb 1, 2013 | 05:19 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Nixx,
Seems Bentley has figured out the P Brake light issue is some failed sensor that needs to be replaced, so this is common/defect. As for the other thing, probably just a small 'reset' could fix it.
Old Apr 8, 2013 | 03:36 AM
Mooikut's Avatar
Mooikut is infamous around these parts
I'm a new owner and from what I've heard tire sensor light is the most common light to come on - I've also been told vw tire sensors which are much cheaper than Bentley will also work
Old Apr 8, 2013 | 03:59 AM
Yes, simply cross reference the VW Phaeton for various possible parts substitution / solutions
Old Apr 7, 2015 | 07:50 PM
pupdogg's Avatar
pupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud ofpupdogg has much to be proud of
I am experiencing the same problem. Were you guys able to identify which exact sensor needed to be replaced? My mechanic's VAG-COM shows the problem coming from the rear passenger side wheel. Any help with specific part numbers will help! Thank you in advance.
Old Apr 9, 2015 | 02:50 PM
It's the rear right (passenger side on USA spec). Part # is....
(Getting my service book, brb)
Brake Actuator 3W0907801E ($252 in May 2010, we did a core return of the old one)
Also see in August 2010 I had the same problem (yellow crossed out P) and they replaced 3W0698996E electric parking brake ($400.19). Odds are THIS is your problem more than the first one ($252).
Hope this helps.
Old Apr 20, 2015 | 07:11 PM
pupdogg's Avatar
@stevenrmusic thank you so much brother! that worked like a charm...only a 10min jobbie. It was in-fact the Electric Parking Brake (3W0698996E) causing the issue. Got the part from FlyingSpares.
Simply took the rear passenger wheel off and got the electric parking brake swapped after removing the 2x star screws that hold it in place. New unit comes with 2x brand new screws.
Old Jan 27, 2018 | 02:57 PM
pmancari's Avatar
pmancari is infamous around these parts
Question "Please check brake lights" message
DOES ANYONE KNOW WHAT TO DO TO FIX THIS MESSAGE "PLEASE CHECK BREAK LIGHTS"
SEE PIC BELOW
Old Dec 20, 2019 | 02:32 AM
Adler2501's Avatar
Adler2501 is infamous around these parts
SEE PIC BELOW
this is one of the worst ones. It’s your third (top rear window) brake light. Very common continental issue. Around $2700 to fix.
recommend to find a shop that will issue inspection sticker with this light fault. Otherwise ur out some serious $$$
Old Dec 21, 2019 | 06:09 AM
Yoghurtshotgun's Avatar
Yoghurtshotgun is infamous around these parts
Originally Posted by stevenrmusic
That is good news and 3 days means ship out of factory in England (1 day), in transit (1 day), and finally get to USA dealer (1 day), so 3 days is about right.
Believe me not many parts are made in the UK any more .more likely shipped from Germany or China 😂
Old Dec 21, 2019 | 09:14 PM
Randy V's Avatar
5 Year Member
Randy V is infamous around these parts
You guys are replying to a thread from 2011.
LOL
Whacky
Old Jun 6, 2020 | 09:54 AM
pierre yves's Avatar
pierre yves is infamous around these parts
Hello @pupdogg,
I have a 2008 Continental GT speed and I have the same issue: P crossed signal.
I'm ready to buy the part. Is it easy to do job ?
Due to that issue, I can't be sure to engage the jack mode (no information on the board).
It's a left drive car ( french )
Do you know if I can find a tutorial to help me or do I have to go and see a mecanic ?
Thank you for your help.
Pierre-Yves
Old Apr 18, 2021 | 09:14 AM
cerex's Avatar
cerex is infamous around these parts
did you ever sort out a DIY instructions, just got the same warning this morning
Old Apr 18, 2021 | 10:27 AM
Johnny Hotspur GT's Avatar
Administrator
​​​​​​Hello @cerex ,
To which which warning are you referring to, as this thread was taken off topic of parking brake warning, if it is the brake light warning, see the DIY thread by @Zaos in the link below.
https://www.6speedonline.com/forums/...ent-howto.html
Johnny
Old May 4, 2021 | 05:38 PM
cerex's Avatar
Interesting enough I got both errors discussed on this thread.
3rd Brake light out - sourced a new brake light and looking for an indy shop in NU/NY/CT/PA area to sort out, Dealers wants close to $2K in Labor
(P) fault came on, I might be lucky for now as I did the Parking Break engagement 5 times and has since disappeared.
If there is a DIY instruction out to replace the faulty sensor/brake part suspect others might benefit as well.
Many Thanks as always Jonny for keeping us all on track and informed
Alex
