Bank 2 o2 sensor workaround
Old Feb 23, 2017 | 08:41 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
Originally Posted by jim2331
.....do you think the damage to Cat occurred while you owned the 2005GT or during prior owner...what mileage was on car when you repaired...what nuts were titanium...JimB San Francisco
Car had 47K miles at the time. I believe the damage occurred after I bought the car as I put 3,000 kms on it prior to the problem. There are three nuts that hold the flange on the cat to the bolts on the header. These nuts are Titanium.
Old Feb 23, 2017 | 09:10 AM
jim2331's Avatar
jim2331 is infamous around these parts
....hope this exercise puts troubles behind you, thanks for sharing....what did Cat alone set you back, I'm sure you tried all areas to get a good price...JimB
Old Feb 23, 2017 | 09:20 AM
PMS's Avatar
PMS
We`re talking four years ago, but I seem to remember the pre-cat was quite reasonable (circa 720.00 British Pounds). I got it from Scuderia Systems in the UK.
Old Feb 23, 2017 | 09:38 AM
jim2331's Avatar
....sorry...I got engrossed in you getting job done without r/r motor...very difficult...lost sight of fact this was done in 2013-14...still good information...
Has the VAS5054 worked well...I am investigating before committing to purchase of Code Reading System...many variables, many choices...any suggestions for a novice knowing nothing about computers...JimB
Old Feb 24, 2017 | 07:34 AM
PMS's Avatar
PMS
This is not the correct thread to talk diagnostic systems. However, suffice it to say that the VAS5054A is NOT for beginners. It was created for Factory-Trained technicians. It is a very deep Rabbit Hole and you can do serious harm to your car if you are not competent. Just for reference, the manual is over 230 pages. It speaks to the old Chinese Proverb: `be careful of what you wish for, you may get it`.
Old Feb 24, 2017 | 07:59 AM
jim2331's Avatar
....thank you...I will be guided accordingly...JimB
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
Oct 7, 2015 12:55 PM
BMW //M
Oct 5, 2015 12:00 PM
