tire pressure
Old Jul 16, 2013 | 11:19 AM
THEBUONONE's Avatar
THEBUONONE is infamous around these parts
Thumbs up tire pressure
hey boys when you have 20 inch rims on your gt what tire pressure should they be at????
Old Jul 16, 2013 | 11:59 AM
Dr.Disaster's Avatar
Dr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to all
Depends on what kind or tires you are running? The OEM tires give quite a range of acceptable pressures requiring more pressure for faster speeds. The front are supposed to be 3lbs. or so higher than rear. I run 44/41 to give safe speeds and descent comfort. Check you owners manuel for the ranges given.
Old Jul 16, 2013 | 12:42 PM
THEBUONONE's Avatar
Smile i am running
oem bentley 20 inch black rims with yokohama tires so what do you think proper pressure should be
Old Jul 16, 2013 | 01:11 PM
Are they max performance summer tires speed rated to 200mph?
Old Jul 16, 2013 | 02:48 PM
THEBUONONE's Avatar
Thumbs up
yes they are..your thoughts????
Old Jul 16, 2013 | 03:17 PM
My thoughts are I need to be safe at high speeds so I set the tires to be run up to 180mph. I have been to 165mph and that is not daily driving but I want to be prepared to go fast. I think the max pressure on the Y rated tires are about 50psi and then you are good to 200mph. I doubt I will get there and I do like a more pliant luxury ride so I opted for less than max. You can run them in the low forties for a better daily ride but not safe at higher speeds.
I went in the upper midrange and did 44psi front and three less in the rear on Pirelli P Zero Rosso, designated with the "B" for Bentley. You must run the three pound difference so do not vary that. If you are less of a speed demon then try 35r and 38f. If you do not like that go up three pound or so at and drive again. Personally I think that is to low for me and would set the front at 41-42 and three less on the rear.
Before you take my word check the dealer that sells those tires and see what he says for a Bentley GT. These are heavy fast cars and need plenty of support. What does you owners manuel say for those tires?
Old Jul 16, 2013 | 03:31 PM
THEBUONONE's Avatar
Smile
thank you brother.....just getting to learn about this beast but what i did was fill the tires with nitrogen which is an amazing feel ....you can really feel the difference you should try it
Old Jul 17, 2013 | 06:54 AM
I've got N in all my bikes and I may have it in the car? I cant remember what happened that long ago.
Old Jul 17, 2013 | 12:17 PM
THEBUONONE's Avatar
lmaoooooooooo i hear that bro
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
The Oss
Aug 24, 2015 08:19 PM
