Squeaky noise from front right wheel area.
Old Jul 25, 2013 | 11:18 PM
jc_333's Avatar
jc_333 is infamous around these parts
I'm got this strange squeaky noise yesterday the front right wheel area. Most likely coming from suspension as applying brakes makes no difference.
Suspension was set in comfort mode so thought maybe something is rubbing. Stuck it back in normal mode and still the same but after a short drive it went away.
Anyone know what this squeaky noise could be as it pretty loud as one can hear it inside cabin. Both upper n lower arms have been changed. Drop links are still original but would like some input before going for a service.
Old Jul 26, 2013 | 05:01 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Suspension bushing probably.
Old Jul 26, 2013 | 04:29 PM
damon@tirerack's Avatar
Moderator
Did you switch from rubber to polyurethane bushings? If so they may need to be greased.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Jul 26, 2013 | 08:36 PM
jc_333's Avatar
Suspension n bushes are all OE.
May be its the weather but will have checked it out. Anyone know if we can get polyurethane bushes for our car?
Old Jul 28, 2013 | 10:50 AM
REDNOSEGT's Avatar
REDNOSEGT is infamous around these parts
Not got a gt
But you can use a8 w12 bushings , I have seen some performance stuff for them
Old Jul 29, 2013 | 02:42 PM
BentleyF's Avatar
BentleyF is infamous around these parts
Bushings
how much are the A8 bushings v/s the dealer? what years for the a8? I think its time for mines to be done now.
Old Jul 29, 2013 | 09:30 PM
REDNOSEGT's Avatar
What bushings do you need? Front upper control arms ?
Old Jul 30, 2013 | 12:39 AM
BentleyF's Avatar
The front don't know much about them at all. its just starting to feel a little lose when I hit bumps.
Old Jul 30, 2013 | 02:39 PM
REDNOSEGT's Avatar
Diagnose at a mechanic first
Usually the front upper arms go bad, 4 arms in total
I can get you the bushings for these arms in poly or rubber
Or just replace the entire arm with new balljoints
put a load on the suspension with a breaker bar to see if anything if anything is loose
And look at them to we if any cracks are present
Old Aug 1, 2013 | 11:18 AM
BentleyF's Avatar
Enemy
Nov 10, 2015 08:01 AM
COBB Tuning
Nov 9, 2015 08:02 PM
New991S
Aug 31, 2015 05:22 PM
ModBargains
Aug 20, 2015 12:28 PM
pwdrhound
Aug 20, 2015 05:54 AM
