Does my horn sound normal?
Old Sep 14, 2013 | 10:36 AM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
Hi,
I recently discovered that my horn doesn't sound normal compare to other cars like Merc/BMW. It sounds more like a clown car than Bentley.
Could you please listen to this and see if it sounds like your horn:
https://soundcloud.com/user537313602/horn
It feels like the bass is missing.
Old Sep 14, 2013 | 10:52 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
I have just had the very same problem.
The lower horn of the two had rusted up so badly that it wouldn't work.
I fitted a new one and all is back to normal.
Replacement is by removing the front right inner arch liner. The horns are at the front, you can't miss them.
The faulty one was a right pain to get off due to seized nuts though.
Regards. Les.
Old Sep 14, 2013 | 10:56 AM
lilo1980's Avatar
Thanks Les. Do you mind telling me where did you purchase the replacement horn and how much was it? Secondly, did you have to remove the wheel as well?
Old Sep 14, 2013 | 11:12 AM
ExSF's Avatar
Hi Lilo.
Yes, wheel off job and the bolts holding the inner arch are the 'Torx' type.
I happened to have a spare horn in the garage from some years ago. It was one of a pair that I used to fix the same problem on one of my Jaguars.
I wouldn't mind betting that VW horns are the same, not sure about the 2 pin connector though!
If you are OK with altering the wiring connections then any aftermarket high/low tone horn would work.
Les.
Old Sep 14, 2013 | 11:29 AM
lilo1980's Avatar
Originally Posted by ExSF
Hi Lilo.
Les.
Thanks Les. I will look for some vw horn.
Old Sep 15, 2013 | 02:23 AM
ExSF's Avatar
Hi again Lilo.
I saw some VW ones on ebay and the connectors do look the same. Some show the part number as well so that may help.
Les.
Old Sep 15, 2013 | 04:49 AM
lilo1980's Avatar
Hi again Lilo.
Les.
Thanks Les. I found this as well: http://www.vwparts2go.com/oem-part/v.../3d0-951-221-c
I will go to a local VW dealer to pick one up. I absolutely love the VW Phaeton connection because otherwise, it will be insanely hard to source some parts!
Fester
Sep 8, 2015 09:35 AM
John@SpeedTech
Sep 4, 2015 07:23 AM
SRC4S
Sep 1, 2015 09:22 AM
Rodolfo
Cayenne 958
Aug 28, 2015 03:03 PM
The Oss
Aug 24, 2015 08:19 PM
