change empty key batteries
Old Oct 11, 2013 | 06:00 AM
ccwboy's Avatar
ccwboy is infamous around these parts
anyone was try to change key batteries by yourself ? is it start from this gap?
Old Oct 11, 2013 | 07:50 AM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
no,you need a small flat bladed screw driver and at end where key ring would attach insert screw driver in between two halves,it is tricky and if you don't get it right you can damage key.
Old Oct 11, 2013 | 08:19 AM
ccwboy's Avatar
thank for the advice.so lucky you reply me quick then i go get this small screw driver.im done. is so easy and im gonna upload the pic to share all cgt driver
Old Oct 11, 2013 | 08:25 AM
ccwboy's Avatar
here we go 1st step use this small screw driver put into the tidy gap.put it out and use the screw driver to open bentley logo cover.it open.finish.so easy.2min
ID:	289176   Click image for larger version
ID:	289177   Click image for larger version
ID:	289178   Click image for larger version
Old Oct 11, 2013 | 04:17 PM
White991TT's Avatar
White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !
Great Post Thx!
Old Oct 14, 2013 | 06:11 PM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
Great pictures! Thanks.
Old Oct 15, 2013 | 03:00 PM
Dr.Disaster's Avatar
Dr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to all
I did it but would not really say it was easy or uneventful. I had a hard time separating the halves and then getting back together having some difficulty with the rubber. I practiced on the valet key and ended up bruising the plastic.
Old Oct 16, 2013 | 09:39 AM
ccwboy's Avatar
i found some pic.they open the key like this way..anyone try??
ID:	290516   Click image for larger version
Old Oct 16, 2013 | 09:42 AM
ccwboy's Avatar
i was so worry about that.can't find many info on internet about open the key.bentleytech remind me use small flat bladed screw driver.i'm so lucky to DIY didn't get broken&scratch...that's y i share some pic for you guy.
Old Oct 16, 2013 | 10:08 AM
those pics above are the correct way to do it,if you are not careful you can damage key ring holder ,thats why dealers keep that part in stock !
Old Oct 16, 2013 | 11:16 AM
Post #8 is the way I did it and I did gouge the plastic a bit, oh well.
Old Oct 17, 2013 | 08:13 AM
Lars_Tempest's Avatar
Lars_Tempest is infamous around these parts
Hi, Post 8 is the correct way and what Bentley recommends - flat screwdriver carefully from the end of key by the keyring..ease the clamshell cover apart and voila! Hope that helps, I would not try by the badge..much easier to damage it there..
Old Oct 17, 2013 | 08:43 AM
I must have missed the "key" word.
Old Oct 17, 2013 | 09:56 AM
Love your pic ... but is that a Dominican ???
No sir Habanos. That is a Por Larranaga Petit Corona. Thank you.
Old Oct 17, 2013 | 10:10 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
EVERY time I used Post #8 it broke the small plastic bit that holds the other keys/keyring.
