Continental gt ECM relay?
Old Nov 1, 2013 | 11:23 PM
turbo_secret's Avatar
turbo_secret is infamous around these partsturbo_secret is infamous around these parts
Got code P0688 (engine control module/ powertrain control module power relay sense ciruit /open) does anyone know what this mean or where the engine control module relay is?
Old Nov 2, 2013 | 12:02 AM
White991TT's Avatar
White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !
According to Ross-Tech, Start Here....
17072/P0688/001672 - ECM Power Relay Load Circuit: (J271): Open Circuit
Possible Symptoms
Engine Coolant Fan running at full Speed while Ignition is OFF and Engine is COLD (could lead to discharged Battery)
Possible Causes
Fuse(s) faulty
Power Supply Relay for Engine Control Module (J271) faulty
Terminal 87 faulty/hanging
Wiring between Engine Control Module (J220) and Power Supply Relay for Engine Control Module (J271) faulty
Possible Solutions
Check/Replace Power Supply Relay for Engine Control Module (J271)
Check Wiring between Engine Control Module (J220) and Power Supply Relay for Engine Control Module (J271)
Check/Replace Engine Control Module (J220)
Old Nov 2, 2013 | 02:33 AM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
in the engine compartment,if left hand drive the E-box fuse and relay box is on the right side corner near the windshield.
adnanm3
Oct 25, 2016 08:38 AM
pwdrhound
Sep 13, 2016 10:44 AM
nitrorocket
Sep 25, 2015 08:48 PM
FUTURESTAR
Sep 23, 2015 05:42 PM
geetee
Cayenne
Sep 11, 2015 06:35 PM
