05 BCT wheel well buzz
Old Apr 7, 2014 | 03:28 PM
rojolo's Avatar
rojolo is infamous around these parts
Greetings,
I have a buzzing sound coming from the right front wheel well area. It will stop but start again when I put my foot on the brakes.
Is this normal or is something about to pick my back pocket.
Old Apr 7, 2014 | 04:48 PM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
that buzzing noise is the vacuum pump,usually on the left hand side or steering wheel side if you have a left hand drive,the fact it goes off is good news ,if it doesn't go off or comes on prematurely you usually have an air leak that can be quite expensive.
Old Apr 7, 2014 | 04:56 PM
rojolo's Avatar
Thank you for the good news!
Cheers
Old Apr 15, 2014 | 08:40 AM
rojolo's Avatar
The buzzing still bothers me as it seems excessive - it seems to be on a lot.
How long should it run before shutting off - no running issues/codes.
I'm such a newbie.
cheers
Old Apr 16, 2014 | 04:05 AM
it should only run a couple of secs,one way of testing is rapidly press brake pedal and see how many presses you get before buzzing,if it buzzes on acceleration you probably have a leak. you will not necessary get codes.
Old Apr 16, 2014 | 05:02 AM
rojolo's Avatar
Well, I noticed it started while accelerating yesterday so it looks like I have a leak. How critical is it to get it in the shop?
Regards
Old Apr 16, 2014 | 05:36 PM
well really unless you get a fault code appear,check engine light it is just how annoying it is,on an 05 they can do it without engine removal depends on the garage.
Old Apr 16, 2014 | 06:42 PM
rojolo's Avatar
I dropped it off at the dealer today so i'll keep you informed.
Old Apr 17, 2014 | 07:23 PM
rojolo's Avatar
Bummer - huge leak so they have to drop the engine. Such is life.
cheers
Zero911
Aug 24, 2015 06:51 PM
Aug 21, 2015 09:56 AM
ModBargains
Aug 20, 2015 12:28 PM
