05 bentley continental gt sensors
Old Jul 27, 2015 | 03:09 PM
mwang218's Avatar
mwang218 is infamous around these parts
Just picked up a CGT... got 2 warning lights on , need a little help PLEASE... 1st one I read about getting a code reader V Checker V102 to reset TMPS light... 2nd light has a P with a slash going across... what's that and how do I fix it, I think it looks like parking brake or something. .. check my electric parking brake and it work fine and release fine???
Thanks Mike
Old Jul 27, 2015 | 03:54 PM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
both are common, with the tpms meaning you'll need new sensors in the tires and/or brain for it. The parking brake is probably the rear right e-brake sensor bit, which as I recall is only a few hundred to fix.
Old Jul 27, 2015 | 05:34 PM
mwang218's Avatar
Ok. Thanks. .. As I was reading through the stuff. I thought the TPMS can be bypassed with the V102 ... as I do not need the sensor telling me tire pessure.
Old Jul 28, 2015 | 04:58 AM
Yes, there are threads here where you can bypass the TMPS system if you feel you don't need it. As I recall, it also involves removing a fuse, so seems easy The threads here on 6Speed have all the info so use the search function.
Old Jul 28, 2015 | 06:12 AM
mwang218's Avatar
Thanks. Can anyone show me a pic of the right side E brake sensor. Thanks
Old Aug 10, 2015 | 03:33 PM
mwang218's Avatar
Yes I bought a vchecker V102... i reset the tmps. But it come back on again, the V102 does not have where I can input a code... just has read error msg and clear msg??? Thanks for any help.
Old Aug 11, 2015 | 07:25 AM
MikeH's Avatar
MikeH is infamous around these parts
Looking at the difference between the 102 and 202(which is listed in the guide for resetting TPMS) the 102 is "without can-bus" which im assuming doesnt allow you to change coding.
My guess is you will need the 202 or some other device?
Old Aug 11, 2015 | 08:21 AM
mwang218's Avatar
Ok. .. thank you for your help.
hdc4
Bentley
11
Jan 6, 2019 07:17 AM
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
smartbot
Cayenne
Oct 13, 2015 06:08 PM
FUTURESTAR
Sep 23, 2015 05:42 PM
WheelB
Sep 3, 2015 10:26 AM
