VAS 5054A help
Old Oct 24, 2015 | 08:54 AM
dulay's Avatar
dulay is infamous around these parts
VAS 5054A help
So my engine light came on and I figured I would get one of those scanners and see if I could diagnose this myself before I asked the mechanic.....
Got the device and installed it. Plugged in the VAS5054 with USB cable. Software said connection with vehicle established when I keep the foot off the brake and turn the key.
It tells me to turn on the ignition. I start the car but the software still has an X through that as though the car is not on. What am I doing wrong.
Funnily enough just as I am doing this the check engine light goes out!
Any help appreciated. and I did change the admin selection to Bentley. Once I get this fixed I will try the blue tooth adapter for the VAS.
Remy
Old Oct 25, 2015 | 01:44 AM
turbo_secret's Avatar
turbo_secret is infamous around these partsturbo_secret is infamous around these parts
Mine can't connect to the Bentley automaticly either. I have to select vw phaeton and 6.0 engine and it goes through. Try that
Old Oct 25, 2015 | 06:46 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
I have an Autel scanner. With that it simply asks for the ignition to be switched on.
Try that and see if it helps.
Les.
White991TT
Mar 8, 2016 06:01 AM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
Sizzle Chest
Florida
Oct 2, 2015 04:40 PM
nephew
Sep 30, 2015 06:57 AM
pumalex
Sep 27, 2015 08:58 AM
