No power/electronics unless car is running? Help
Old Nov 28, 2015 | 11:06 AM
turbo_secret's Avatar
turbo_secret is infamous around these partsturbo_secret is infamous around these parts
Im having some problems with my 05 continental gt. All my electronics such as lights/ remote key fob wont work if the car isn't actually running. Even if i turn the ignition on, the only thing that turns on is the speedometer. Then after i start the engine, everything starts working. Is there a module or something acting up? Where do i start? And the check engine light is not on. Thanks
Old Nov 29, 2015 | 08:33 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
what is the condition of your two batteries? Are they fully charged?
Old Nov 29, 2015 | 09:21 AM
Yea they are brand new. Just bought both of them at autozone.
Old Nov 29, 2015 | 09:35 AM
PMS's Avatar
PMS
Can you more precisely describe the symptoms? Key out (what works)/key in but not turned (what works), key in and turned (what works and what lights show on the dash), starting symptoms, etc.? On the surface, it would indicate your house battery isn't charged/connected but your starter battery is working.
Old Nov 29, 2015 | 09:44 AM
So basicly nothing ever works if the cars engine isnt running except for the speedometer. And on the speedometer it says visit workshop before i start it but the check engine isnt on? And when i start the car it starts fine and then all the electronics work but as soon as i shut the engine off, everything stops working. Its weird
Old Nov 29, 2015 | 09:48 AM
PMS's Avatar
PMS
when the key is turned, but not to the point it engages the starting protocol (just turned on), what lights do you see on the dash gauges? Additionally, have you tried the emergency starting procedure? I know your car starts, but have you tried turning the key to the left for 10 seconds until you hear a click?
Old Nov 29, 2015 | 10:12 AM
So when i turn the key. It says please start the vehicle or something like that while at the same time another screen pops up and says key fault visit workshop. And no i havnt tried the emergency procedure i dont know what that is?
Old Nov 29, 2015 | 10:48 AM
PMS's Avatar
PMS
Sometimes the starter battery is not strong enough to start the car. By turning (and holding) the key to the left for 11 seconds, the house battery is engaged for starting the car. I have suggested you try this just as a preliminary step. Is it possible the key fob battery is weak (you are getting a key fault)? Do you have a second key fob? If so, try that key. The more precise you can be on the actual faults showing up, the easier it will be to diagnose your problem.
Old Nov 29, 2015 | 02:57 PM
Oh thats nice to know. I had no idea. So when i got the car the key fob wasnt working so i thought the battery was bad. I changed the battery in the key fob. Unless maybe i have to program it? But i dont think its the key fob. Im guessing it might be a module or ignition because whenever i shut the car off, theres like a click noise in the trunk before everything shuts off?
Old Nov 30, 2015 | 07:32 AM
PMS's Avatar
PMS
You shouldn't have to programme the key when you change batteries in the fob. The fact your car starts, indicates the ecm recognizes the key fob. However, you have reported that you are getting a key fault error. Do you have a 2nd key? If so, try that. Do you have access to a diagnostic scanner? This will be the quickest way to determine the cause of your problem.
Old Nov 30, 2015 | 08:13 PM
Yea it says system fault visit workshop and it has a key logo above it. And no i dont have a second key :/ closest bentley dealership is 3 hours away. Theres a local vw dealership wonder if they can hook their computer to the car?
Old Dec 1, 2015 | 07:12 AM
PMS's Avatar
PMS
Yes, underneath the covers, your car is very similar to the VW Phaeton. Your local VW dealer should be able to diagnose your issue.
Old Dec 8, 2015 | 12:05 AM
nguyennhatquang's Avatar
nguyennhatquang has a spectacular aura aboutnguyennhatquang has a spectacular aura about
u has bad keyfob...transponder inside is bad
Old Dec 8, 2015 | 12:36 AM
blackbull's Avatar
blackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond repute
Ding, ding, ding......we have a winner!!!
Old Dec 8, 2015 | 01:07 AM
Can volkswagon dealer program a new key? Because the bentley dealership is like 4 hours away. Also are you sure that would be causing all the electronics to just shut off like that?
