Check Engine Code P050A
Old Mar 7, 2016 | 04:12 PM
alexob53's Avatar
alexob53 is infamous around these parts
The 2007 Continental Flying Spur threw a check engine code the other day. Just got around to checking it, and when I started it the check engine light was gone. It had stored the code, though, and it ended up being P050A, Cold Start Idle Air Control System Performance. Since I cleared the codes, it hasn't come on again. I never felt like it was having trouble idling when first started, but I will keep carefully observing. It has less than 12k miles, and hasn't had a problem before. Any ideas? Not too worried since it hasn't yet come back, but thought I would throw it out there to see if anyone's heard about it. Thank you!
Alex
Old Mar 12, 2016 | 06:36 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Hi.
Just make sure that the battery is charged as a low charge can cause all sorts of spurious faults.
The drive probably charged it anyway hence the check lamp not coming back on.
Les.
REKX
Feb 4, 2016 11:56 PM
bansasn
Cayenne
Jan 31, 2016 11:59 PM
hollynitro
Jan 29, 2016 11:29 AM
DerekShiekhi
Audi
Jan 28, 2016 05:52 PM
