cgt 2005 Cd player / add a phone cable
I have a Cd changer in the glove box. I assume if I can remove it I will find a line level cable going out of the Cd to the amplifier where ever that is. I assume this is a normal 2x cable for left and right possibly with rca Jacks on it, possibly it's hard wired but still a line level cable.
Questions :
1) can I patch another cable onto this cable with a phone jack so I can play music from the phone instead of the tv. ?
2) same question but add a Bluetooth device instead of cable
3) where are the screws to remove the Cd player and any guidance on doing it carefully.?
Questions :
It is not a normal RCA cable PLUS you need to 'fool' the car radio into electrically sensing there is a CD changer hooked up. Remove the CD changer and for $35 it is plug 'n' play easy to have RCA jacks.
https://www.amazon.com/gp/product/B000CK1WI2/
As for BlueTooth and how to remove disc changer, please use the SEARCH function as it has been covered many, many times over. Thx.
Questions :
Questions :
https://www.amazon.com/AFA-1C0-051-5...d+removal+tool
Basically, you will need to remove the CD changer and use a Dice Mediabridge or other unit if you need RCA or 1/8" stereo input and Bluetooth. i gave up on Bluetooth, frankly, and so the unit on Amazon i posted above was my final choice.
FYI: Tried four solutions (Bentley stock Apple input unit, two by Dice....) and in the end gave up on BT. Too much trouble plus i use a Samsung Gear S2 watch for speakerphone. If you truly must have Bluetooth speakerphone above all else, Bentley does sell a newer module for around $650 plus install at http://www.flyingspares.com/shop/blu....html?___SID=U
i can do this on laptop but not phone - is that normal ?
So in doing some research it looks like I'm stuck with a CD Nav system in my 2006. Is it correct that you can't swap out the reader with a 07-09 DVD unit which would be really nice since they are available all over for cheap. I came up with info part number 65 90 2 365 696 which is a 2015 update and advertised as the last update edition. BMW dealers have them list priced for just under $200. I also see them elsewhere for less. I really only need one disk and that one is listed on Ebay for $85 which is not a great deal as for $100 more you can have the complete set and new. So the question is, is this information all correct? After this I'm making another acknowledgement timer like I did on my 05 infinity G35 so I don't have to hit that stupid disclaimer button every time i start the car. Thanks T.
Not sure if anyone has tried the DVD substitute for the CD version to see if it works. Perhaps start a new thread as we've veered off topic. As for acknowledgment, I'd love to know how to defeat them.
I was to understand that the head and the wiring harness would need to be changed to convert to the dvd reader. I have not seen a plug picture or a wiring diagram to see if there is compatibility between the CD and DVD units. As far as the module you can PM me and I can explain the details.
T.
T.
