adjusting ride height at faster speed
Old Apr 23, 2017 | 03:55 PM
MrVette's Avatar
MrVette is infamous around these parts
Around here we have deep gutters in a number of locations. I drive slowly through them but have found underneath the front bumper still scrapes. Unfortunately found this after I paid to have the front bumper removed and repainted. Now it is scraped again.
Solution is to raise the ride height. Problem is the system is designed to automatically lower the car again as speed increases and it does not return to the higher height I selected when the car slows down. Thus I constantly need to check on the ride height and reset it to high. Major pain and easy to forget to do.
The local speed limit is 70 mph through town so I often get to that speed or slightly faster. About 70 must be where the car is set to automatically lower. I'd like to adjust this to a higher speed like 80 mph. Can that be done somehow?
Old Apr 25, 2017 | 08:26 PM
MrVette's Avatar
Noticed today owners manual says height will lower at 75 mph. Same as my experience. Anyone know how to change that to a higher speed?
Old Apr 26, 2017 | 01:45 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
I think you will need someone with Vag Com diagnostics to reset the parameters. I'm sure it would be possible somehow.
Good luck with it.
Les.
