opinion: bentley to maserati
i currently have an low mileage 05 bentley mulliner gt and was considering a 2011 lower mileage maserati quattroporte...any opinions in regards to maserati's reliability/cost of service compared to bentley
...no issues with the bentley...is it worth it to switch out or keep the bentley..i know there totally different types of cars
thanks in advance
thanks in advance
thanks in advance
thanks in advance
look at this thread:
https://www.6speedonline.com/forums/...ttroporte.html
now that I have the bentley for nearly 2 years I confirm that the maintenance costs on the CGT are higher than the maintenance costs of the Maserati.
I have no experience with the post 2011 models.
Hi Steven,
all in all the Maserati is 30/35% cheaper to maintain than the CGT.
I have had no problem with the car except standard maintenance.
if you buy one don't forget to check carefully:
- the SYHOOK suspension (it's +/- 1000€ a piece)
-be sure it has the ZF gearbox and NOT the DUOSELECT.
Time for a change, and while the convertible top is still all good... The GTC is B #2 and have had a B for about 8 years now. Did the Ferrari thing, the ricer thing, the big truck thing...
Gotcha 👍👍
...hello Joek...a while back you said you had good experience with Sumitomo...does your opinion still hold and how much mileage you get from set...what car do you have now...thanks JimB
I ran a Bentley Arnage T and a Maserati QP for a couple of years. THe QP was a "duo select" which took a bit of mastering.They eat clutches every 15000 miles at about £1700 apiece. The depreciation however was greater on the QP. so I kept the Arnage. You need to get a QP with a conventional auto box and avoid the diesels which are rapidly becoming unacceptable.
Paul
Paul
@jim2231
my bentley specialist swears by them...the yokohamas made for bgt wears out too fast...lasted only 7k miles...got about 20k miles with 5k rotations on the sumitomos...ride is quiet and smooth...on my 2nd set...still have the gt...still looking around for other options since it is my 3rd car & only has 21k miles on it
