A/C Blowing Problem
Old May 8, 2017 | 09:13 PM
therron4ou's Avatar
therron4ou is infamous around these parts
A/C Blowing Problem
As you probably read on here last week, I had to replace the vacuum pump. When I got it back from diagnosis, the a/c would come on but wouldn't blow... like the doors weren't opening to the a/c. They hooked up it up their computer, reset it, and everything was good. Tonight the problem happened again. Driving down the road, the a/c comes on, but no air blows. Any idea whats going on?
2007 Bentley GT
Old May 9, 2017 | 04:22 PM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
Do you have the vag com scanning tool?
do you hear the AC running but just no air from any vents?
does hot air comes out if you turn up the temperature?
Old May 9, 2017 | 08:03 PM
therron4ou's Avatar
Yah I hear the the a/c running but u can tell it's blocked. It's only sometimes though. It sat overnight and worked find this morning. Going to have my mechanic hook up vag com tomorrow and see whatsup
Old May 9, 2017 | 10:53 PM
lilo1980's Avatar
The AC vent has some sort of actuator that controls the flaps. It is closed until the A/C temperature has reached the desired level.
Old May 15, 2017 | 11:54 PM
therron4ou's Avatar
Has worked fine ever since. I'm not sure what caused the two glitches.
Old May 16, 2017 | 07:04 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Certain electrical systems are prevented from working when the battery charge is low, maybe it was that.
