2013 Bentley Key Fob Battery
Old Feb 25, 2018 | 12:48 PM
BentleyBill's Avatar
BentleyBill is infamous around these parts
i think the battery on my 2013 bentley is needs a change but I can't open the key fob. Any advice~?
Old Feb 25, 2018 | 04:48 PM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
Use the "search" function in this forum. You will find specific instructions..
Old Mar 2, 2018 | 03:26 AM
quarryman's Avatar
5 Year Member
quarryman is infamous around these parts
Very good utube video if you search utube for it.
Old Mar 3, 2018 | 03:50 PM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
Yes, there is a good youtube on it, just search for it. FOB takes a 2032 battery.
If you cannot find the youtube, just GENTLY pry the two halves apart from the rear of the FOB by the key ring using s small flat blade screwdriver. Gently so as not to damage the rubber outer skin. It will come apart....be careful...
SHANKENFELTER
Dec 22, 2003 07:19 PM
buddyg
Sep 15, 2003 11:03 AM
