Intermittent fault with seat
Old May 9, 2018 | 11:45 AM
massf's Avatar
massf is infamous around these parts
Hi guys
New member so apologies in advance for any errors!
I have a 2004 Continental GT and the passenger seat has an intermittent fault whereby sometimes it just won't work at all and other times it will work fine.
The previous owner had this looked at it seems and some work was done but the problem is still there
Has anyone else come across this issue?
Old May 10, 2018 | 01:07 PM
mjorgensen's Avatar
mjorgensen is infamous around these parts
A guess would be that your previous post about the battery is also causing this issue, the Bentley is very sensitive to voltage issues.
Old May 11, 2018 | 10:07 AM
massf's Avatar
Hopefully that's all it is, as I found some paperwork from the previous owner showing that he took it into Bentley and they thought it could be a control unit within the seat that needs replacing, to the tune of about £1000!!!
We'll see soon.......
Old May 11, 2018 | 10:09 AM
mjorgensen's Avatar
Even if it is just a battery you can easily spend $900 usd. for 1 battery. Good luck hope it is something simple for you ;-)
Old May 11, 2018 | 10:11 AM
massf's Avatar
Thanks buddy. New battery cost me £132 with a 5 year warranty on it. Hopefully that'll cure 99% of the small issues I've been having.
healthyspeed
Cayenne 958
Sep 14, 2023 12:38 PM
onefastman1
Jan 11, 2018 09:50 AM
Yotam Refael
Cayenne 955/957
Oct 4, 2015 07:59 AM
toughluck
Feb 25, 2014 08:42 AM
AdamT
Mar 24, 2006 12:58 AM
