Stalling 30 sec after start
Old 12-27-2018, 03:56 PM
c0ke's Avatar
c0ke is an unknown quantity at this point
Any chance anyone can help me out? Fixed a vacuum leak and the car was running fine for a few days and now this. Starts to back fire and pop and die after running for about 30 seconds to a minute it's completely un driveable
Thursday,27,December,2018,17:52:03:61536
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64) HEX-NET CB: 0.4436.4
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: SCBCR63W85C025162 License Plate: RICHIE
Mileage: 157600km-97928mi Repair Order:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCR63W85C025162 Mileage: 157600km-97928miles
Address 01: Engine Labels: 07C-906-018-BEB1.clb
Part No: 07C 906 018 AF
Component: BY-6.0L-TT G ª6503
Revision: 54ÿTT Serial number: 000-00018.08.
Coding: 0000173
Shop #: WSC 00000 000 00000
VCID: 699A6ABF4189820262-513C
2 Faults Found:
19475 - Valve for Exhaust Flap 1 (N321)
P3019 - 004 - Open Circuit
18331 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 09E 927 760 C HW: GS1 904 1
Component: AG6 09E 6.0L W12TT 1903
Coding: 0000101
Shop #: WSC 00083 000 00000
VCID: 302CC7DBA2D333CA65-5160
No fault code found.
Address 03: ABS Brakes Labels: 3W0-614-517-V1.lbl
Part No: 3W0 614 517 D
Component: ESP 5.7 4WD H01 0021
Coding: 0007878
Shop #: WSC 40329 000 00000
VCID: 3620F1C340B71DFA3F-51CE
3 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
000 - - - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 R HW: 5WK 470 26
Component: D2 Kessy 6610
Revision: 66105312 Serial number: VWZ3Z0D7244257
Coding: 0139501
VCID: 3424CBCB56CB0FEA01-5160
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
7 Faults Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
01176 - Key
008 - Implausible Signal - Intermittent
00956 - Key 2
00668 - Supply Voltage Terminal 30
009 - Open or Short to Ground - Intermittent
00087 - Terminal 30 for Starting Relevant Consumers
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00172 - Key 2 not learned
Address 06: Seat Mem. Pass Labels: None
Part No: 3W0 959 759 A
Component: CM Seat Pass. 0009
Coding: 0000002
Shop #: WSC 30900 104 60964
VCID: 47DE8C07375D947254-5160
6 Faults Found:
02569 - Control Module for Massage (J740)
00003 - Control Module
012 - Electrical Fault in Circuit
012 - Electrical Fault in Circuit - Intermittent
01975 - Passengers Seat Height Adjustment Motor (V191)
01903 - Seat Tilt Adjustment Motor (V231)
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 008
Component: ZAB COCKPIT 0223
Coding: 0400325
VCID: 6A9815B3448F891A6B-5160
8 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
00384 - Optical Databus
00386 - Negative Output Audio Channel for Speech/Telephone
00387 - Plus Output Audio Channel for Navigation Announcements
007 - Short to Ground - Intermittent
00856 - Radio Antenna
00823 - Line-Output; Front Left
00385 - Positive Output Audio Channel for Speech/Telephone
Address 08: Auto HVAC Labels: None
Part No: 3W0 907 040 B
Component: Climatronic BY614 0030
Coding: 0000002
4 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
014 - Defective - Intermittent
00926 - Terminal 30
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
004 - No Signal/Communication - Intermittent
00445 - Loss of Refrigerant
000 - -
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 H
Component: STG.Bordnetz 5101
Coding: 0000106
Shop #: WSC 05013 104 61211
VCID: 2F2EC4A7BFED2C327C-5160
2 Faults Found:
00576 - Terminal 15
00907 - Intervention load Management
000 - -
Address 11: Engine II Labels: 07C-906-018-BEB2.clb
Revision: 51ÿTT Serial number: 000-00018.08.
Coding: 0000173
1 Fault Found:
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0P Airbag 8.4E+ H10 0936
Coding: 0012368
VCID: 2502268FED11666286-5160
1 Fault Found:
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D
Component: Lenksäulenmodul 3401
Coding: 0000012
VCID: 2E10D9A3B8E7253A77-5160
1 Fault Found:
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No: 3W0 920 841
Component: KOMBIINSTRUMENT RB8 0520
Coding: 0023203
Shop #: WSC 02028 002 1048576
VCID: 72A80DD36C5F41DAD3-5160
10 Faults Found:
00457 - Control Module for Network (J519)
00466 - Control Module for Steering Column Electronics (J527)
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
01320 - Control Module for Climatronic (J255)
01330 - Central Control Module for Central Convenience (J393)
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
01305 - Databus for Infotainment
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70AC07DB625373CA25-5160
15 Faults Found:
00461 - Control Module for Seat Memory; Passenger (J521)
00908 - Control Module for Wiper Motor
01308 - Control Module for Roof Electronics (J528)
01327 - Control Module for Parking Aid (J446)
01335 - Drivers Seat/Mirror Position Control Module (J543)
Address 34: Level Control Labels: 3D0-907-553-V1.clb
Part No: 3W0 907 553
Component: LUFTFDR.-CDC- 3C1V0 7014
Coding: 0015500
Shop #: WSC 19681 002 1048576
VCID: 77BE3CC7073D24F2E4-5160
2 Faults Found:
00778 - Steering Angle Sensor (G85)
01598 - Drive Battery Voltage
Address 36: Seat Mem. Drvr Labels: None
Part No: 3W0 959 760 A
Component: CM Seat Driver 0008
Coding: 0000002
Shop #: WSC 05013 104 180634
VCID: 3FCE94E76F8DDCB2EC-5160
5 Faults Found:
01971 - Adjuster for Seat Heating & Ventilation (E399)
00998 - Motor for Driver's Seat Recline (V45)
Address 37: Navigation Labels: None
Part No: 3W0 919 887 A
Component: NAVIGATION 0168
Coding: 0400000
VCID: 45C2860F0D518662A6-5160
1 Fault Found:
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 C
Component: Dachmodul 0703
Coding: 0000157
VCID: 3620F1C340B71DFA3F-5160
1 Fault Found:
00926 - Terminal 30
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 F
Component: 1X HSG 0101
Coding: 0000032
Shop #: WSC 03167 104 53710
VCID: 3326C8D753C508D218-4B00
Subsystem 1 - Part No: 3W1 959 701
Component: Tuersteuergeraet FS 0702
Subsystem 2 - Part No: 3W1 959 702
Component: Tuersteuergeraet BF 0702
Subsystem 3 - Part No: 3W8 959 703 A
Component: Tuersteuergeraet HL 1002
Subsystem 4 - Part No: 3W8 959 704 A
Component: Tuersteuergeraet HR 1002
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0020
15 Faults Found:
00576 - Terminal 15
01134 - Alarm Horn (H12)
00987 - Lamp for Brake Light; Left (M9)
00988 - Lamp for Brake Light; Right (M10)
00118 - Drivers Defroster Button (E323)
00131 - Outside Door Handle Illumination/mirror Light Driver Side
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
01735 - Potentiometer for Mirror Adj. Horizontal; Pass. Side
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W0 035 456 C
Component: 12K-AUDIOVERST 4121
1 Fault Found:
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 B HW: 3W0 907 801 B
Component: EPB BC6HX23 HC6 X230
Coding: 0022401
VCID: 3522F6CF5DB116E236-5160
2 Faults Found:
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 55
Time Indication: 0
Freeze Frame:
Voltage: 6.31 V
Count: 200
01487 - System Function Test
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Voltage: 0.72 V
Count: 184
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 H
Component: Heckspoiler 0002
VCID: 302CC7DBF2D333CA65-51CE
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W1 955 023 C
Component: WischeX
Shop #: WSC 00000 725 65552
5 Faults Found:
014 - Defective
00459 - Control Module for Display and Input; Front (J523)
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 C
Component: Batteriemanagement 2700
VCID: 23063897E3259852E8-5160
5 Faults Found:
00085 - Starter Battery Switch-Over Relay (J580)
00086 - Parallel Battery Connection Relay (J581)
011 - Open Circuit - Intermittent
00576 - Terminal 15
00093 - Terminal 15 for Starting Relevant Consumers
Address 76: Park Assist Labels: Redir Fail!
Part No: 3W0 919 283
Component: 02 Einparkhilfe 0203
VCID: 7AB825F3342F399A9B-5160
1 Fault Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Address 77: Telephone Labels: None
Part No: 3W0 035 729 K
Component: Telefon 0252
1 Fault Found:
End----(Elapsed Time: 07:27, VBatt start/end: 11.6V/12.9V. VIgn 0.0V)------
Old 12-27-2018, 04:22 PM
c0ke's Avatar
Here is the log after clearing all, starting the car and letting it stall then rescanning
Thursday,27,December,2018,18:25:26:61536
www.Ross-Tech.com
VIN: License Plate: RICHIE
Coding: 0000101
Coding: 0007878
Coding: 0139501
Component: ELV XXXX
1 Fault Found:
011 - Open Circuit
Coding: 0000002
2 Faults Found:
Coding: 0400325
1 Fault Found:
Coding: 0000002
Coding: 0000106
Coding: 0000173
1 Fault Found:
Coding: 0012368
Coding: 0000012
Coding: 0023203
Coding: 0000006
Coding: 0015500
2 Faults Found:
Coding: 0000002
2 Faults Found:
Coding: 0400000
Coding: 0000157
Coding: 0000032
Coding: 0022401
Component: WischeX
End----(Elapsed Time: 07:59, VBatt start/end: 12.2V/11.9V. VIgn 0.1V)------
Old 12-27-2018, 04:38 PM
1eapplebaum's Avatar
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
At a glance: p1923 indicates ecu fault. Check connections for corrosion. Location under wiper plastic panel on right side. Also, some faults can be set by an old battery. Have a battery load test when drivable.
Best of luck.
Old 12-28-2018, 04:09 AM
BWings's Avatar
BWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud of
What happened to Address 01 in the followup scan (post #2)? It is missing in this paste.
Old 12-28-2018, 07:24 AM
c0ke's Avatar
Just double checked it. There was no 01 in the scan log,
I rescanned 01 only and still got
Friday,28,December,2018,09:20:32:61536
VCDS Version: Release 18.9.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Control Module Part Number: 07C 906 018 AF
Component and/or Version: BY-6.0L-TT G ª6503
Software Coding: 0000173
Work Shop Code: WSC 00000 000 00000
2 Faults Found:
P1923 - 008 -
Also noticed last night while working on it there seems to be a solenoid in the center rear of the engine that once it enables (or disables) is when it stalls out, it sounds like a vacuum leak for the first 30 sec while its running once the solenoid changes the sound goes away and it sputters then stalls. However I have been unable to find anymore vacuum leaks the conventional way with a stethascope and moving stuff till I find it, might have to smoke test it but I am unsure where to start smoke testing it due to all the one way check valves. If anyone could give me a pointer on the proper way to smoke test the vac lines I will do that next. Thank you.
Also the battery codes are because I've had it sitting for months with this problem because I havent been able to figure it out without going nuts after every 4 hour period of trying.. There isn't much info out there on these cars unfortunately
Is there a way to monitor fuel pressure using vcds? It smells very lean could it be a fueling issue?
Old 12-28-2018, 08:14 AM
c0ke's Avatar
The area by the regulator on the right at the bottom there is where it sounds like a leak that goes away and it stalls
Old 12-28-2018, 08:16 AM
PMS's Avatar
PMS
PMS is offline
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
ALSO...check your batteries AND your alternator. You are getting too many "low voltage" errors.
"...If anyone could give me a pointer on the proper way to smoke test the vac lines I will do that next. Thank you."
Bentley smoke test :
Old 12-28-2018, 09:23 AM
Long shot possibility: exhaust flaps deploy apx. 30 sec. after start. They are vac. activated. Check system. There are two vac. globes at each rear muffler flap to check.
Check (left side) static battery voltage, if below 12.3 charge it. Than turn on lights for 30 sec. than turn everything off and recheck voltage should be < 12.6 volts. Below parameters stated indicate failing battery. Running voltage would be worth noting if possible.
The solenoid suspected of vac. noise needs to be identified. That said what is it's nomenclature? Than a better evaluation is possible.
The ecu fault identified hopefully is just battery related.
What year is the patient?
Old 12-28-2018, 10:18 AM
c0ke's Avatar
I identified it as a fuel regulator of some sort, disassembled it and all seals are good, definitely not the issue I will check the rest of what you said. Also still have to smoke test it I will do that after I check the exhaust flaps and battery, I have a charger on it as like I said it was dead outside before I brought it in so hopefully that's not the issue. ECUs under the R/H plastics seem to be in good shape without corrosion.
It is an 05
Old 12-28-2018, 10:29 AM
Any history of vac lines above transmission being fixed? This is a chronic vac. leak source. Eng out job.
An inspection camera can be fished from above to check stated lines.
Old 01-03-2019, 01:37 PM
c0ke's Avatar
Smoke tested it, vac leaks are too small to identify with engine in. Started pulled it looks like debris in secondary cat on drivers side possibly a plugged cat causing this too?
Old 01-03-2019, 01:56 PM
Anything is Possible. Wouldn't expect a clogged catalytic converter to cause the describe problem above to occur so suddenly. Usually when catalytic converters clog there are other symptoms. Gathering from your post sounds like the engine is being removed?
Another approach is to erase the trouble codes and start from scratch. This being said one would be able to see which trouble codes are reset and go from there.
Old 01-04-2019, 09:05 AM
c0ke's Avatar
Yes, we did erase all codes and start over. Apparently he's been having these vacuum problems for 2 years in an out of one shop who apparently didn't care about him or didn't know what they were doing. I replaced about 6 vacuum lines and the car was fine, including repairing (jbweld) one of the one way check valves that run down the passanger side behind the steering rack sent him away and now a week later he has returned with this problem (the car is totally undriveable). We should have the engine out today
Old 01-04-2019, 10:24 AM
There are 2 fuel pump relays in the trunk. Switch around posiion of relays. See if this changes things. With engine out this isn't possible, so pull relays and check per test meter. One fuel pump relay is primary, start up and drive. The other is the auxiliary pump relay during high load and boost.
Also, check vacuum pump for operation left wheel well.
While the engine is out check all wire loom covers, usually brittle and possible exposed wires. The PCV pipes to intake manifold are usually brittle and break. Major vacume leak area when they break. Repair with 3/8 transmission rubber hose line.
Old 01-31-2019, 08:25 AM
c0ke's Avatar
Engine is back in, we updated all the vacuum lines on the tranny and replaced with cupronickle and proper rubber hose, vacuum pump is working and we have smoke tested all lines about 3 times each. We also found and replaced a plugged cat. Both fuel pumps are good. The car sounds much healthier and we can now get it to stay running passed 30 seconds however it still sputters then stalls after running for 30 seconds when the idle tries to drop down. It still sounds like when the idle drops down a vacuum leak "shows itself" but it's only audible I cannot find it with a smoke machine. I am going to pull the intake manifold and replace the plugs and change that gasket also.
Any ideas on why this could still be happening after 30 sec?
Quick Reply: Stalling 30 sec after start
