Stalling 30 sec after start
Old 02-11-2019, 08:39 AM
c0ke's Avatar
c0ke is an unknown quantity at this point
Thanks, I have sent him a PM and asked if he has a few minutes to look over the thread hopefully we can get this bypassed
  #32
Old 02-11-2019, 08:52 AM
PMS's Avatar
PMS
PMS is offline
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
I know how difficult this situation can be. I'm not sure my (resolved) issue bears any similarity with your situation, but you may wish to check out this thread:
https://www.6speedonline.com/forums/...-when-hot.html
My problem turned out to be caused by impedance in the wire coming out of the ECU. This was due to broken filaments within the wiring case. Unlike your issue, It would only manifest in extreme conditions.
  #33
Old 02-18-2019, 08:56 AM
BentleyF's Avatar
BentleyF will become famous soon enough
my bet is primary fuel pump is bad. Secondary pump starts the engine and cuts off after 20 seconds or so. It will then only kick in under hard acceleration they both work. I had simular issues in a spur my other flying spur. I replaced both pumps with vw phateon w12 pumps.
less than $500 for both.
The reason your car runs when you jumped the circuit is that secondary pump did not lose power, however if you leave it bridged it will kill your battery as it will run constantly.
  #34
Old 02-18-2019, 09:27 AM
1eapplebaum's Avatar
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Indeed a possibility. Before pulling everything apart this can be tested at the relay. Pull the relay, on the primary positive and ground check if there is resistance. No resistance is an open circuit, bad pump.
  #35
Old 02-25-2019, 02:23 PM
c0ke's Avatar
Just got back from St Lucia and while I was there this exact thought hit me. Jumping the relays kept "both" pumps on aka the only working one. I had the guys replace the primary pump and the car seems to be running perfect.
  #36
Old 02-25-2019, 04:23 PM
Outstanding!!
  #37
Old 01-30-2023, 10:41 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
that was a great troubleshooting session guys... i am super impressed...
what i thought when first read rhay jumping all fixed the problem i would just reconnect the relay banks - so the primary will start be a 2nd and 2nd pump will be the primary
no idea if technically possible to switch like that but would try so then will eliminate at least the fuel pump defects.
and here is the question - the both fuel pumps are identical /have the same params.
so in any emerg situation that one will fail the other will work we can switch them and ok... wont involve the broken 2nd in case of boost but you can operate the car right?
but smb said that on start engine the both pumps are engaged - the 2nd for 30sec.
is this correct? even if yes - it is no problem to start the care without 2nd pump operating?
  #38
Old 02-21-2023, 11:23 AM
sazam's Avatar
Originally Posted by 1eapplebaum
At a glance: p1923 indicates ecu fault. Check connections for corrosion. Location under wiper plastic panel on right side. Also, some faults can be set by an old battery. Have a battery load test when drivable.
Best of luck.
did a scan today and have similar error
1. most important for me "18331 - please check drc memory of ecu number 2 - p1923 - 008 - intermittent"
you say - look for corrosion so should i disconnect bateries and then disconnect the plug from ecu located under the windshield plastic cover and finally apply some wd40?
this is what should be done?
and anyone can tell me how this connection look like to find the right one?
2. i also get in address 05:
"00181 - access/start authorization antenna (in rear bumper) (r136) 011 - open circuit"
something serious / what is this? what is its role where it is needed and how it looks like? should i check for broken connector here or smth?
3. finally i got the address 09: "01335 - drivers seat/mirror position control module (j543) - 004 - no signal / communication"
and correlated with that probably address 36: "01976 - seat depth adjustment motor (v234) - 005 - no or incorrect basic settings / adaptation
and correlated with that probably address 46: "01335 - driver seat/mirror position control module (j543) - 004 - no signal / communication
for this related to seat it looks like it is the reason i can not do memory set for driver seat - ive asked for help in other thread
i can not successfully do the callibration manually and with vcds i also can not do it - when being in " basic settings reset" the process starts and... the depth motor starts running but this part of the seat under the knee does not move so there is no way to understand by the computer it reaches the limits (thru resistance check i think) - so the procedure can not be completes - and no basic settings reset means no chance to make memory seat alive.
this is my theory - hope somebody will verify if i am right or not
thank you in advance for your help
  #39
Old 02-21-2023, 11:37 AM
BWings's Avatar
BWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud ofBWings has much to be proud of
P1923 is NOT A FAULT. It simply directs you to check codes on the second ECU. This, by far, is the most confusing P-code in the VAG series.
  #40
Old 02-21-2023, 01:44 PM
sazam's Avatar
ok - so...
a) i shouldnt bother with the "corrosion" suggestions?
b) silly question - how to check on second ecu? i did only auto-scan so far and no other customizations
  #41
Old 02-21-2023, 02:18 PM
BWings's Avatar
ok - so...
silly question first - the second ECU reports on vcds as address 11. When it has faults then address 01 reports a p1923. It directs you to look at the second ECU (address 11) for additional faults not listed or attributed to ECU 1.
On the first question check for corrosion as an incidental but it is not what p1923 means.
  #42
Old 02-21-2023, 03:20 PM
sazam's Avatar
suspected it will be addr 11 - great name "engine ii" - but... there are no faults...
will do the stuff with ecu 2 corrosion check... but pls suggest me the procedure
should i disconnect batteries or this is not needed?
and finally apply some wd40 in plug and socket? wd40 is ok, or may lead to damages in electronics?
and anyone can tell me how this connection look like to find the right one / this?
do i need to remove some parts to get into the right plugs to check?
NoName
Bentley
01-09-2023 04:15 PM
xclens
Bentley
10-03-2022 01:44 PM
V12diablo
Bentley
04-08-2022 03:33 AM
Realdeal12
Bentley
14
01-26-2021 06:14 PM
silentspeed
Bentley
07-20-2015 02:08 PM
Quick Reply: Stalling 30 sec after start
