gt 2005 - access/start auth antenna - keyless opening stopped working
Old Feb 22, 2023 | 10:06 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
ok now i know it is serious... remote keyless opening stopped working
1. worked fine, no manipulations with anything
2. connected rosstech & did scan and clear errors and rescan got this:
address 5 - acc/start auth
"00181 - access/start authorization antenna (in rear bumper) (r136) 011 - open circuit"
3 and from now on i can not open the doors in keyless mode
i need to open it thru button on rc
a. any suggestions why it happened after just scan clear and rescan?
b. how to fix - i mean what i should start with?
ty in advance for help
very first time scan i did after receiving rosstech
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 Q HW: 5WK 470 22
Component: D0 Kessy 6610
Revision: 66105312 Serial number: VWZ3Z0Dxxxxxxx
Coding: 0155885
Shop #: WSC 00083 000 00000
VCID: 33330xxxxxxxxxxxxxxxxxxxxx
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
5 Faults Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
00184 - Control Circuit for Engine Start/Stop Switch
008 - Implausible Signal - Intermittent
01176 - Key
00668 - Supply Voltage Terminal 30
009 - Open or Short to Ground - Intermittent
00087 - Terminal 30 for Starting Relevant Consumers
cleared the errors
restarted scan and from now on i have only this error all the time
Revision: 66105312 Serial number: VWZ3Zxxxxxx
Coding: 0155885
VCID: 33330Cxxxxxxxxxxxxxxx
Subsystem 1 - Part No: 4E0 905 852 D
Component: ELV 1834
1 Fault Found:
011 - Open Circuit
btw - i did not start / tried to start the engine so far, i am hoping this failure only impacts the keyless door opening
DR3ADKN0T
Bentley
Aug 30, 2023 10:00 AM
sazam
Bentley
Jan 21, 2023 10:47 PM
sazam
Bentley
Jan 15, 2023 12:33 PM
kelmas
Bentley
Sep 22, 2022 01:06 PM
Mark C
Bentley
15
Apr 11, 2021 11:49 AM
