headlight teliscopic jet
hi so I heard you have to remove bumper headlight and wing to change the headlamp washer arm has got a split in it so leaks when operated is there an easier way of doing this many thanks nick.
The washer jet is attached by 3 screws to the bottom of headlight which makes it a complete pain to replace.it depends what part of the jet is broken as it does come in two parts.what I did was operate the jet so it pops out grab it with a pair of grips and get a friend to out a cable tie on it past the jet part and hold it whilst I popped the c clamp and removed the squirter part and replaced it with new .very fiddly and very delicate operation though.arw you sure it's the jet part itself not the hose split against the body
Another thing I did to replace a blocked jet is just prise the cap out with the jet and it’s pipe on .Its spring loaded to close ,the water pressure opens it out .
Then clamp it out with a lockable hose clamp .Then work on it .
I think in the U.K. there’s a MOT issue re HD lights and functionality of the head light washers .Bit of a grey area ?
Some “ old school “ turn a blind eye , other jobsworth will fail it until it works properly.
David_M_Chubb
Bentley
Dec 31, 2018 11:33 PM
motoadve
Cayenne 955/957
Nov 20, 2008 09:36 AM
vipertestarossa
Jun 2, 2004 02:37 AM
