05 Bentley Valve cover gasket replacement
Old Mar 25, 2019 | 10:17 AM
ishotdasheriff08's Avatar
ishotdasheriff08 is infamous around these parts
Talking 05 Bentley Valve cover gasket replacement
Hello team, I looking for any advice on replacing the valve cover gaskets on my 2005 Bentley GT. I will also be doing the spark plugs and already took notes from previous post on here in ref to replacing the spark plugs.
Second question is with the multiple left hand battery draining issues, I too an experience that issue. I test all the relays and found the Battery relay P/N 3D0906383 was bad. I have not received my replacement but will update the team if it fix the issue.
Old Mar 25, 2019 | 10:41 AM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
Hi:
If you're following typical procedures to change spark plugs (by removing the entire intake as a complete assembly), then you'll be in an ideal place to change gaskets on valve/cam covers. Here are two pics when I changed my spark plugs. It would have been an easy job to replace gaskets too at this point.
Regarding your second Q. I have not experienced battery draining on the main, but I do keep mine constantly on a C-Tek 7002 tender when the car is parked in the garage. Interested to hear what you come up with.
ECS Tuning - BMW
BMW Vendor Classifieds
Oct 9, 2014 02:27 PM
ciaka
Cayenne 955/957
May 8, 2014 04:42 AM
ciaka
Cayenne 955/957
Oct 3, 2013 07:10 AM
khairo82
Cayenne 955/957
Dec 19, 2011 10:08 PM
Thierry
Sep 16, 2009 02:20 PM
