Obd codes help
Old Jun 2, 2019 | 07:06 PM
Stephen Perez's Avatar
Stephen Perez is infamous around these parts
Obd codes help
I have a 2008 bentley gtc and i have 2 codes that came up 1321 and 1323. Can anyone help me fix these codes. Ie what should i replace to delete them. Thanks Steve
Old Jun 4, 2019 | 04:34 PM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
Hi Stephen:
Are these P-codes? P1321; P1323?
If so, these are knock sensor codes. Two of the knock sensors are no longer reporting so the ECUs detected failurs and sent the CELs. Not very likely these are failed knock sensors simultaneously; more likely a wiring issue via the sensors.
Old Jun 4, 2019 | 05:04 PM
Hi Bwings yes they are p codes. Ill check the wiring as you recommended and i give you an update if that fixes the check engine light problem. Thanks Stephen
Old Jun 4, 2019 | 05:11 PM
BWings's Avatar
5 Year Member
OK Good Stephen. Interested in hearing back.
These knock sensors play a vital role in OBDII Engine management systems by contributing to the control of engine timing. Therefore, the sensors are monitored and have to "report in" they are active and alive even if there is no engine knock. In your case, two sensors are no longer reporting they are active. Again, not likely they both failed, so more likely something has interrupted their signal.
All the Best,
Steve
Mr. C4
Apr 17, 2011 08:18 AM
skandalis447
Feb 16, 2010 04:11 AM
Sendero
May 15, 2008 03:52 PM
Ubermensch
Jul 8, 2005 07:35 AM
