Hot
Old Jun 21, 2019 | 08:32 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Hot
I've noticed on these Bentley the engines are verifiable furnaces. I'm sure that this heat is a contributor to some module failure. Certainly the vacuum line problem of the early models was exacerbated by the heat. Residual heat from the engine once parked, the garage gets quite warm. Lately I've taken to opening the hood to dissipate the heat. Also installed a fan with a 1 hour timer to blow on the motor. Perhaps it's over kill but easy to do.
Old Jun 23, 2019 | 06:16 AM
John R. Allen's Avatar
John R. Allen is infamous around these parts
Great idea...I park mine in the garage and the temperature climbs 15+ degrees when I come in from a drive!
Old Jun 23, 2019 | 08:31 AM
Samhain's Avatar
Samhain is infamous around these parts
That's not a bad idea.
Old Jun 23, 2019 | 01:43 PM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Mind showing us your fan setup? We sometimes keep our Dogo in the garage and it gets pretty hot in there even with the door crack after a nice ride.
Old Jun 23, 2019 | 02:01 PM
5 Year Member
This is low-tech. I purchased the plug-in Woods timer. Set it for 1 hour. The fan is plugged into the timer. This is a standard house fan. In the garage there's a shelf above the engine hood with a fan angled down at the engine compartment.
Old Jun 23, 2019 | 02:53 PM
Veteran: Navy
Oh damn...simple yet functional. 😂 I’m kicking myself because I use a Woods Wifi plug for my deck lights and the heated water bowls and heat lamps for the outside dogs kennels for the winter. I should have thought about that.
Old Jun 24, 2019 | 11:15 AM
Samhain's Avatar
Think I'll try that. Thanks!
vk430gt
Sep 23, 2008 03:56 PM
Blazing
BMW //M
34
Feb 19, 2007 06:32 PM
