Continental gt 05 EPB
Old Aug 9, 2019 | 08:51 AM
Jonty1951's Avatar
Jonty1951 is infamous around these parts
Hi Have problem with left EPB actuator ,on car does not work,off car it does by bench testing, anybody know what power reading I should get from the female connector on the car when operating EPB switch,also any suggestions as to what else maybe giving the problem TIA
Old Aug 9, 2019 | 01:27 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
[QUOTE=Jonty1951;4795013]Hi Have problem with left EPB actuator ,on car does not work,off car it does by bench testing, anybody know what power reading I should get from the female connector on the car when operating EPB switch,also any suggestions as to what else maybe giving the problem
Just throwing some ideas out. Some owners have reported after replacing the switch in the vehicle has fixd the problem. Try removing the connection on the opposite side and testing what your voltage reading is and compare it to the bad side?
Nairb999
Bentley
15
Mar 20, 2017 05:40 AM
Aron
Oct 27, 2003 06:52 AM
jackyjhuang
Aug 11, 2003 09:54 AM
