X's 7000 battery conditioner
One more fyi...
the instructions call for changing one of the fuses from 5A to 20A, so you might have to check the value of the existing fuse for the 12V cig socket, if you do the cigarette lighter method.
https://www.flyingspares.com/uploads...structions.pdf
And with that being said, a member on here from the UK, UKGT, sold me the cigarette lighter part that’s already in the car. I’m going to install it to the right side battery when I get time. I have two 7002 chargers and I’m using the clamps on the right side battery now. To me it’s just better to trickle them both while it’s sitting up for the winter.
Heres a mad idea, at some point buy 2 more chargers take them apart make a panel for the wall fit the electronics behind the panel and install the panel into the wall in the utility room, wire the cables all concealed all the way to the garage have a box with 2 female plugs on the garage wall another 2 cables to go from the box to the boot, so then I don't even need to go into the garage to check, before that brainwave comes to practice better check on the volt drop garage is down the yard.
Anyone needs a drawing I can post one up ...
Robbin bastards how the hell does a piece of wire and socket cost that much.i do have the cigarette style lighter at the rear so I'll be chopping and connecting a make cigarette lighter connector thanks guys
when you showed the socket yesterday I thought you were wiring in a lead for the battery didn't know you had a outlet in the boot ... how much was the lead ...
