Egts 2004 Bentley continental GT
Old Oct 15, 2019 | 07:41 AM
Yoghurtshotgun's Avatar
Yoghurtshotgun is infamous around these parts
Hi guys what side of the engine is egts 1 my iets manual has stopped working thanks
Old Oct 15, 2019 | 09:41 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
It is on bank 1 which is the left side of the motor (facing from the front). I just changed mine and it is VERY difficult to reach with conventional tools. You will need a half socket and a flat bar extension to reach it.. Bentley has a special tool just for this issue. The temp sensor on bank 2 is MUCH easier to access. Good luck!
Old Oct 15, 2019 | 12:01 PM
PMS's Avatar
PMS
Old Oct 15, 2019 | 12:55 PM
Originally Posted by PMS
Thanks PM's I'm such an idiots!!I bought the circuit board to repair these egts and as my manual on my laptop packed up I took it for granted and replaced the UK passenger's side ha ha I'd had a few issues that side getting hot,i changed it only to have the bank 1 sensor pop up on the diag machine again guess I'll order another ha ha they are a fraction of the price of a new sensor but it does help if you swap the right one out ,I can't believe my stupidity
Old Oct 15, 2019 | 12:56 PM
PMS's Avatar
PMS
Old Oct 15, 2019 | 03:06 PM
Might do that one tomorrow 😂😂 re
Old Oct 15, 2019 | 03:19 PM
Originally Posted by Rico.Adams
Just read your post, we've all done it the past mate, all the best ...
Ha ha Rico remember we were chatting in another thread I wrote about the egts and one of the guys said to try the circuit board swap as per one of the Audi threads.well I but the bullet and thought I'd have a go.i didn't even remove it from the car just undid the connector and pulled the box to the top of the engine and unsoldered it and re soldered the new board it was relatively easy I've taken a few pics to post up here being all smug that I'd achieved it only to realise I'd swapped the wrong one ha ha .well atleast I know the one I took out was good and the replacement was a success because that also works 😂😂😂 I might just resolde the board into the other module tomorrow and see what happens .
Old Nov 13, 2019 | 02:21 PM
New board
Decided to do it in place saves removing it out if the exhaust
Cover turbo pipe
Remove lid with screwdriver
After popping off lid with screwdriver clear off sticky coating gel flux just the 5 terminals then heat with a soldering iron
As your heating gently pry from underneath with a small screwdriver
Remove board and clean as much out as possible
Now could mea the fidly bit. My iron packed up so had to go pinch my partner's from her hobby box.not the best iron so soldering was hard. The prongs that need a dollop of solder don't like solder so you need to be quick.add heat dab solder and remove leaving a bit behind on the prong
Add flux and dab wire on and add heat quickly removing iron
Voila some very shoddy soldering but all connected .re seal lid with silicone and put it all back together
Old Jan 26, 2020 | 09:46 AM
gregwarner's Avatar
gregwarner is infamous around these parts
Where did you get the replacement circuit board? Did you have to buy the whole assembly and strip out the board, or can it be bought separately?
Old Jan 27, 2020 | 01:21 AM
I bought just the boards from a company called sidmotorsport email them and they sell you the one for the Audi bituro (same board ) then clear out original box with silicone in it and replace with the new ones
Old May 2, 2022 | 06:39 AM
Boydonegood1's Avatar
Boydonegood1 is infamous around these parts
Hi guys.
I’ve got a Exhaust temp sensor bank 1 fault code up. Has put engine light on but no other issues.
could this board be my saviour?
is Sidmotorsport the Polish site?
really appreciate any advice. Thanks. Terry
Old May 11, 2022 | 06:05 PM
tteplitzmd's Avatar
5 Year Member
tteplitzmd is infamous around these parts
There is an excellent youtube video on replacement of the sensor (not the board).
My bank 1 went and replacement of the sensor, while difficult fixed the problem.
You can OEM and non OEM sensors from Flying Spares.
Old Nov 14, 2022 | 10:11 AM
Langer59's Avatar
From: Germany, Strullendorf (Bamberg) and Bad Pyrmont.
Langer59 is infamous around these parts
Special tool homemade
Yep, I can confirm this. We have built our own tool, sacrifying a 17 nut, cutting it in half and weld it to a flat iron bar. It worked out well, but only after using induction heating.
Old Jan 1, 2024 | 11:38 AM
smallclaims's Avatar
smallclaims is infamous around these parts
Exhaust Sensor Circuit Boards
Could you tell me from where you purchased these circuit boards please with contact details?
Thank you in anticipation
Old Jan 1, 2024 | 04:27 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
https://g.co/kgs/EMLrRTb
Email Sid motorsports and advise them of your vehicle to confirm which version EGT/PCB board is appropriate for your Bentley. The company is in Poland. Essentially they are providing the Audi Bi turbo version if I recall.
