Rusty Rear Badge!
Old Dec 14, 2020 | 09:17 AM
rich9911's Avatar
rich9911 is infamous around these parts
Rusty Rear Badge!
Looks like I have a few rust bubbles brewing up from under the boot lid badge.
Is this common? It's an 09 car.
I'm going to pop off the boot trim to have a proper look when it stops raining.
Didn't really expect these cars to start rusting! Maybe the paint got chipped when the badge was installed.
Old Dec 15, 2020 | 09:04 AM
rich9911's Avatar
Oh and any tips for getting the badge off?
I just managed to get the two, almost impossible to reach, nuts off the back. Is it glued on too?
Do I need to get the hair dryer out?
Old Dec 15, 2020 | 10:28 AM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
Accident damage repair.
Old Dec 15, 2020 | 02:16 PM
rich9911's Avatar
No I don't think so. The inside of the boot is perfect.
Old Dec 15, 2020 | 11:09 PM
xclens's Avatar
5 Year Member
xclens is infamous around these parts
I purchased a new one of those on eBay from England for like 30 bucks. My B-button is missing a little bit of paint, and I'm picky about that sort of thing.
I haven't replaced mine yet, but there are two screws and it is also secured with double-sided tape on both sides of the button.
Old Dec 16, 2020 | 03:22 AM
rich9911's Avatar
Thanks! Yes it feels like it's stuck on... That will make it just that little bit MORE awkward to get off!
Old Dec 16, 2020 | 05:16 AM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
Dental floss and / or heat gun
C
Old Dec 16, 2020 | 12:24 PM
rich9911's Avatar
So my title is wrong! No one picked up on it???
It's not rust, its aluminium oxidisation creeping under the paint.
I got the badge off today and its a bit of a mess under there!
It clearly started where the badge bolts have broken the paint and allowed water to start reacting with the aluminium.
Old Jan 2, 2021 | 02:19 AM
xclens's Avatar
5 Year Member
Did you get it solved?
Do you have any tips on how to reach the back of the badge (inside the trunk lid)? Was it difficult removing the inner panel? I wish I had a guide where all the tabs & screws and such are located.
Old Jan 2, 2021 | 03:15 AM
rich9911's Avatar
Not completely fixed yet. Just waiting for better weather. The badge comes off with application of some warm air and removing the two nuts on the back, which are really awkward to get at. You need some small sockets and ratchet spanners and wobbly bars to get in there as they are hidden behind stuff.
The rear boot lid trip pips off, but you have to have proper trim removal tools as the Bentley trip clips are a nightmare. Really strong grip on the bodywork and the other end is just glued onto the back of the trim so if you're not careful, the clips stay in the bodywork and the holders break off where they are glued.
I got all the oxide off an etch primed it. 90% of the damage is under the badge so it doesn't have to look perfect. Main thing is to stop its progress under the paint. Once it warms up a bit, I'll get it finished off.
Old Jan 6, 2021 | 04:05 AM
xclens's Avatar
5 Year Member
Thanks for the info, rich9911, and good luck with the remaining work!
I purchased a 30-piece set of "car interior removal tools", with all kinds of plastic and metal tools, so hopefully I'll get the hang of it.
Old Jan 6, 2021 | 04:21 AM
rich9911's Avatar
The plier tool works best. You need to get the forks around the clip and force it apart. Add some tape to the prongs to protect the paint.
While you're in there, make sure the drain pipes are clear and not kinked. One of mine had a twist in it which makes it more likely to block.
Here's the location of the clips:
(you can see the two that detached at the back. probably as the weight of the boot liner dropped or from it being removed before)
Old Jan 6, 2021 | 09:37 PM
xclens's Avatar
5 Year Member
Thank you oh so much, that is incredibly helpful! I'm also going to document my DIY-projects like that, both for future reference and to share here.
Old Jul 13, 2021 | 08:04 AM
rich9911's Avatar
Originally Posted by Greham
I don't know, maybe this information will be useful to you. I treat places like this to prevent corrosion https://www.rustbullet.com/. I learned about this tool at one automotive forum, I am satisfied with its characteristics and quality. I have never seen such a remedy before.
Interesting stuff.
In my case the corrosion is aluminium oxide as the boot is aluminium!
Kind of annoying that they don't treat it from the factory, but then you only need a tiny pinhole in the coating and the corrosion creeps along under the paint.
spooltime
Oct 17, 2017 10:16 AM
plenum
Oct 13, 2014 02:18 PM
opnielsen
Feb 15, 2014 07:31 PM
Paxton
Cayenne 958
15
Jun 9, 2012 10:14 AM
