Battery charger for GT 2008
Old Mar 29, 2021 | 01:54 AM
Pablen84's Avatar
Pablen84 is infamous around these parts
Hello everyone, I am looking for a battery charger for the GT and I have seen that there are original Bentley's on Ebay for about € 500, and there are others from the Ctek brand that are worth half, about € 250.
What I would like to know is if they are really worth it. The car is used approximately once a week, and if you know of a place that is cheaper than Ebay
Old Mar 29, 2021 | 02:52 AM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
Bentley ones are re-branded C-Tek like Maserati and Aston.
Mine is on a C-Tek MX 5.0 and it's great
C
Old Mar 29, 2021 | 02:56 AM
Pablen84's Avatar
Originally Posted by CatmanV2
Los de Bentley se renombraron como C-Tek como Maserati y Aston.
El mío es un C-Tek MX 5.0 y es genial
C
CatmaV2 this one??
https://www.ebay.es/itm/CTEK-MXS-5-0-12V-5A-Batterieladegerat-Battery-Charger/303930237152?hash=item46c3a760e0:g:Zh8AAOSw7NJgWQg J
Old Mar 29, 2021 | 03:01 AM
Pablen84's Avatar
Originally Posted by Dark Green
C-Tek en España por 146 Euros aquí:
I saw this one, but I have to add this If I only want to plug and play.
https://www.ebay.es/itm/Ctek-Bentley-Battery-Charger-Conditioner-Adapter-Cable-2-Pin-Plastic-Type/183452220213?hash=item2ab69abb35:g:h-gAAOSwgbhaNnX0
Old Mar 29, 2021 | 04:32 AM
CatmanV2's Avatar
5 Year Member
Yes indeed. You may need the cigar converter as well:
https://www.ebay.co.uk/itm/CTEK-CTE-56263-CTEK-Cigarette-Lighter-Connector-Adaptor-Black-red/203084949944?epid=17007090225&hash=item2f48ce69b8: g:HAMAAOSwPUNfQTB9
It will depend on what socket is in your car. The esteemed @Dark Green has something different I suspect.
C
Old Mar 29, 2021 | 05:36 AM
CatmanV2's Avatar
5 Year Member
Ahh doh. Not my day today . Is there not a standard 12v socket in the boot as well? I'm sure I started mine with one before the dedicated adapter arrived.
C
Old Mar 29, 2021 | 12:06 PM
Pablen84's Avatar
My female plug is It, which male plug do I need? I am confuse. Cigarrete one or the one of ebay I saw?
Old Mar 29, 2021 | 12:40 PM
CatmanV2's Avatar
5 Year Member
Is that the only plug you have? Can you do a photo of the whole side of the trunk?
C
Old Mar 29, 2021 | 01:07 PM
Pablen84's Avatar
Yes, Of course.
Yes, iis the only one plug I have.
Old Mar 29, 2021 | 01:39 PM
CatmanV2's Avatar
5 Year Member
You need the cigarette adapter.
My car and @Dark Green has another socket below that 12v socket which takes a different plug.
C
Old Mar 30, 2021 | 12:58 AM
Pablen84's Avatar
C
Yes, I think so, thanks!!
Old Mar 30, 2021 | 01:05 AM
CatmanV2's Avatar
5 Year Member
Good luck!
C
Old Mar 30, 2021 | 01:24 AM
Pablen84's Avatar
[QUOTE = CatmanV2; 4872304] ¡Buena suerte!
C [/ QUOTE]
Thank You very much.
I have last question. Wich is better or enough for my use? MSX 5.0 or MSX 7.0?
Old Mar 30, 2021 | 04:15 AM
CatmanV2's Avatar
5 Year Member
I rather doubt there's any meaningful difference. The MX 7 has a higher maximum charge current, but my MX 5 is currently having no issues with my GT and I *know* I have some issue with components not shutting off properly, so it's able to handle that no problem
C
Old Mar 30, 2021 | 04:41 AM
Pablen84's Avatar
Dudo que haya alguna diferencia significativa. El MX 7 tiene una corriente de carga máxima más alta, pero mi MX 5 actualmente no tiene problemas con mi GT y * sé * Tengo un problema con los componentes que no se apagan correctamente, por lo que puede manejar eso sin problemas
C
Thank You
JStiles01
Bentley
22
Jan 31, 2022 07:27 PM
massf
Bentley
May 12, 2018 03:15 AM
compositeguy
Oct 23, 2016 11:50 PM
Leonenglewood
Bentley
May 27, 2010 07:16 PM
vph_tony
Jun 4, 2009 03:00 AM
