If you saw these items on maintenance records.....
Old Jul 13, 2021 | 09:04 PM
captainbaker's Avatar
captainbaker is infamous around these parts
Im looking over a GT on carfax and there is a maintenance event(s) that caught my eye. Sounds like a front end collision of some sort? Overheat? Normally I wouldnt care if it was in the past or a few thousand miles ago, but its recent and within a thousand miles.
Vehicle serviced
  • Maintenance inspection completed
  • Electrical system checked
  • Transmission cooler line(s) repaired/replaced
  • Radiator replaced
  • CV boot(s) checked
  • Thermostat replaced
  • Water pump replaced
  • Maintenance reminder reset
  • Drain plug gasket replaced
  • Oil and filter changed
  • Alignment performed
  • Engine cleaned
  • Serpentine belt replaced
  • Brake fluid flushed/changed
  • Door check replaced
  • Wiper(s) replaced
And less than 1,000 miles later:
Vehicle serviced
  • Engine checked
  • Engine/powertrain computer/module checked
  • Hood shocks replaced
  • Noise checked
  • Window regulator(s) replaced
  • Tire condition and pressure checked
  • Battery replaced
  • Glove box repaired/replaced
  • Engine checked
  • Front wheel bearing(s)/hub(s) replaced
  • MAP sensor replaced
  • Sensor replaced
  • Computer(s) checked
Old Jul 14, 2021 | 06:33 AM
Zaos's Avatar
Zaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond repute
Sounds like Dealer Wealth! Yes always more $$$
Old Jul 14, 2021 | 11:04 AM
Linescreamer's Avatar
Linescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud of
It depends on miles?
Old Jul 14, 2021 | 01:19 PM
Work done at independent shop and total miles under 25,000. Im thinking unreported accident or overheat. There is a story there...I just dont know what.
sempaipaul
Jul 15, 2022 12:03 AM
CWLFielden
Apr 26, 2016 06:55 PM
PianoProdigy
Cayenne 955/957
Nov 19, 2010 09:41 AM
boochook
Aug 16, 2009 04:26 PM
