Renew Control Arm Bushings
Old Aug 3, 2021 | 01:29 PM
Randy V's Avatar
5 Year Member
Randy V is infamous around these parts
My 2009 CGT is beginning to show significant tire wear on the front inners.
An Indy indicates the control arm bushings need replaced.
Can just the bushings be replaced or does the entire control arm need replaced.
A Bentley tech on FaceBook indicates either is achievable using same parts as Audi plus approx. 2 hours labour per side plus 4-wheel alignment.
Thanks for any guidance.
Old Aug 3, 2021 | 01:49 PM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
The lower is Bentley specific, it’s bigger than the Audi .
Although they say an Audi fits its smaller bulk wise .
There are plenty of threads on this , best to buy new .Figure 20-30;K miles consumable parts .
Old Aug 3, 2021 | 02:58 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Can just the bushings be replaced?
https://www.ebay.com/itm/Bentley-Gtc...-127632-2357-0
Yes the bushing can be pressed out and replaced with the above bushings. However, might not be cost-effective. Worth asking the repair shop before buying parts.
We replaced the bushings with the control arm droped down on the bushing side, leaving the ball joint still attached to the wheel. This was done on a lift. A portable bushing press was used.
FIRST_PORSCHE
Nov 5, 2019 07:38 AM
Yoghurtshotgun
Bentley
Aug 25, 2019 03:59 PM
lilo1980
Bentley
18
Sep 29, 2013 03:38 AM
REDNOSEGT
Bentley
Apr 23, 2013 07:17 PM
VAGscum
Jul 20, 2011 08:38 PM
