ECU/Transmission Updates after wheel size change?
Old Aug 29, 2021 | 01:08 PM
DR3ADKN0T's Avatar
DR3ADKN0T is infamous around these parts
Just curious if I should be doing anything after updating my wheels from 22" to 20". I was hoping the speedmeter would have improve but still same +4mph off. I also feel like the transmission is a bit sloppy esp at low speed ~1500 RPM. Not sure if they previous owner tuned the ecu to adjust for the wheel size? Any suggestions would be appreciated.
Old Aug 29, 2021 | 01:38 PM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
Did you adjust the tyre size to maintain the overall circumference?
C
Old Aug 29, 2021 | 01:46 PM
DR3ADKN0T's Avatar
No I didnt. The new tires are 245/40/20, I believe Bentley uses 40 for 19" and 35 for 20" rims from the factory. The old 22" rims had 22 sidewall. I dont see rub being an issue and I dont mind the extra side wall. Is this something I would use VCDS for or should I take this to someone who knows what they are doing?
Old Aug 29, 2021 | 02:28 PM
CatmanV2's Avatar
5 Year Member
I'd suggest, personally (not that I have much value) using a tyre size calculator to work out what the 'correct' size would be (i.e. circumference). If you want to adjust that then, you can correct the mph reading. But it's only going to be correct at one speed.....
FWIW 4mph is not something I'd worry about......
C
Old Aug 29, 2021 | 02:57 PM
DR3ADKN0T's Avatar
I was more worried that I had to recalibrate the ECU for the transmission to adjust for the new rim size.
Old Aug 29, 2021 | 03:43 PM
CatmanV2's Avatar
5 Year Member
I've never seen a car where that was a thing. But anyway, the *rim* is not the issue. The circumference of the wheel / tyre combo *might* be.....
C
saline
Nov 1, 2011 09:29 AM
Gdoc
Cayenne 955/957
Jun 18, 2010 07:07 AM
zambono
Jan 24, 2010 03:14 AM
