I recently bought a 04 GT. When I received the car it started and ran fine, but I know the car needs new front air struts as the front end settles to the ground after a few days.. I had to let the car sit for approx. 2 months as I was rebuilding my sons corvette motor. I finished his car this weekend and went to work on the GT and the car would not turn over. I had the main battery on a trickle charger, but the battery only showed 11.2volts and 3.4 under load. The start battery shows 12.8 volts and 12.4 under load. So I replaced the house battery per the recommended procedure and still have the same issue. I performed a full scan which is attached and I am showing multiple electrical issues. I don't know if this is because the battery was dead and I haven't been able to to get started to reset everything or if I have other issues. I am very good mechanically, but am new to working on such a high end vehicle, any help would be appreciated. Attached is the scan log I did today.
Change the batteries and keep them on a battery maintainer. The cigarette lighter in the trunk will keep both batteries maintained. As stated in the past our Bentleys eat batteries. Once new batteries are installed delete the trouble codes, start the car and rescan. When the batterys lose their potential trouble codes abound from a complaining ECU.
Should good fortune be on your side new batteries will keep the front suspension at the proper level. Otherwise the struts need to be evaluated as well as any potential line leakage.
The main battery is brand new, the start battery is testing very good under load. So I should clear everything with my VCDS, and then try to start the car?
Jason
Well than, of course double check the battery(s) connections. Try turning the key to the left, (emergency start) and then to the right after that.
Check that the carpet on the left front side is dry (driver US). That is the location of the kessey ignition start authorization module. Also check the windshield scuttle. That space sometimes gets clogged with leaves and debris which can casuse water ingress into the ecu's and lead to wet carpets. Clearing the codes will not fix the no-start situation. The multitude of the trouble codes suggests a voltage deficiency. For the record the right side battery is the starter battery.
The carpet is dry, but I am still working on getting it removed to double check. I will double check the batteries connections also. I did try the emergency start procedure several times with no luck. The center gauge is telling me to press the brake while starting, I have it down and I can’t remember if that earring is supposed to go off once depressed. I didn’t know if it could be a possible brake switch issue.
Jason
Jason
Hello @V12diablo
If you are pressing the brake pedal while trying to start the engine, the warning should never be displayed, if you forgot to press the pedal while starting, the warning would then be displayed, but once you press the pedal, it should be gone, so, yes, I would be replacing the brake switch, I have replaced mine twice..
I was able to find the switch locally, I checked the old switch and the switch tested fine, but I replaced it with the new one anyways. I checked continuity on the four terminals and it was the same as the new one. I am still not able to start the car and it tells me to press the brake pedal. The switch I replaced was the brake light switch that mounts to the pedal itself. Is it possible there is a communication issue. I’m not a expert by any means but there seemed to be a lot of communication codes on the log in my original post. I’m not sure where to go from here.
I was recommended by Ewe on the Ross-Tech forum to clear the codes by module. So, I went through and cleared all codes module by module. Some codes came right back, but most did not. I rescanned and attempted to start the car, It started and ran for 2 seconds and shut off. It would do that every time. So I am wondering if there is a issue with the Kessy system. I have attached the before Start and after Start logs.
Jason
Before Start:
Code:
Friday,11,February,2022,17:56:24:53661
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: SCBCR63W04C022240 License Plate: BENTLEY
Mileage: 168790km-104881mi Repair Order:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCR63W04C022240 Mileage: 168790km-104881miles
Address 01: Engine Labels: 07C-906-018-BEB1.clb
Part No SW: 07C 906 018 J HW:
Component: BY-6.0L-TT G ª6240
Coding: 0000173
Shop #: WSC 01666 772 36780
VCID: 2C010BE8AA162EBB2B9-513C
VINID: 8D34938860E70044C008208400746ACBC3
13 Faults Found:
18058 - Powertrain Data Bus
P1650 - 008 - Missing Message from Instrument Cluster
17972 - Throttle Actuator (J338)
P1564 - 002 - Under-Voltage during Basic Setting
18347 - Powertrain Databus
P1939 - 008 - Missing Message from Controller for Access & Start Auth.
18045 - Powertrain Data Bus
P1637 - 008 - Missing Message from Electric Load Controller
18044 - Powertrain Data Bus
P1636 - 008 - Missing Message from Airbag Controller
18036 - Powertrain Data Bus
P1628 - 008 - Missing Message from Steering Angle Sensor
18043 - Powertrain Data Bus
P1635 - 008 - Missing Message from A/C Controller
18034 - Powertrain Data Bus
P1626 - 008 - Missing Message from TCU
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics
18331 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
16885 - Vehicle Speed Sensor
P0501 - 004 - Implausible Signal
Readiness: 0110 1101
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 M HW: 5WK 470 26
Component: 11 Kessy 6400
Coding: 0131309
Shop #: WSC 00083 000 00000
VCID: 2F3B1CE49B0055A30EB-5160
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication
Address 06: Seat Mem. Pass Labels: 3W0-959-759.clb
Part No: 3W0 959 759 A
Component: CM Seat Pass. 0009
Coding: 0000002
Shop #: WSC 34183 002 1048576
VCID: 47CB544413B0EDE326B-5160
6 Faults Found:
01312 - Powertrain Data Bus
013 - Check DTC Memory
01900 - Passengers Seat Fore / Aft Adjusting Motor (V31)
005 - No or Incorrect Basic Setting / Adaptation
01975 - Passengers Seat Height Adjustment Motor (V191)
01904 - Passengers Backrest Adjusting Motor (V46)
01903 - Seat Tilt Adjustment Motor (V231)
01976 - Seat Depth Adjustment Motor (V234)
Address 08: Auto HVAC Labels: 3W7-907-040.clb
Part No: 3W0 907 040 B
Component: Climatronic BY614 0030
Coding: 0000002
Shop #: WSC 00000 000 00000
VCID: 30391F98863E4A5B171-5160
No fault code found.
Address 09: Cent. Elect. Labels:
VCID: 55F78E0CDC0C4F73A47-5160
Note: Excessive Comm Errors
Address 11: Engine II Labels: 07C-906-018-BEB2.clb
Coding: 0000173
4 Faults Found:
Address 15: Airbags Labels:
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D
Component: Lenksäulenmodul 3401
Coding: 0000012
VCID: 2E0501E09C0A5CAB05D-5160
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No: 3W0 920 840 Q
Component: KOMBIINSTRUMENT RB8 0401
Coding: 0023200
VCID: 42DD45503892C8CBF15-5160
1 Fault Found:
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9DF9846BE0A5B571-5160
1 Fault Found:
Address 36: Seat Mem. Drvr Labels: 3W0-959-759.clb
Part No: 3W0 959 760 A
Component: CM Seat Driver 0008
Coding: 0000002
VCID: 3FDB4CA44B60A5239EB-5160
13 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded
02569 - Control Module for Massage (J740)
009 - Open or Short to Ground
00997 - Motor for Driver's Seat Position; Fore/Aft (V48)
011 - Open Circuit - Intermittent
012 - Electrical Fault in Circuit - Intermittent
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
004 - No Signal/Communication - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
01174 - Driver Seat Height Adjustment Motor (V138)
00998 - Motor for Driver's Seat Recline (V45)
17513 - Oxygen (Lambda) Sensor Heating; B1 S2; Heating Circuit
P1105 - 006 - Short to Plus
25970 - Unknown Error Code
Unknown - 000 - - Intermittent
Address 37: Navigation Labels:
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 C
Component: Dachmodul 0702
Coding: 0000189
Shop #: WSC 03224 104 175128
VCID: 36352980645A646B4DD-5160
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 F
Component: 1F HSG 0101
Coding: 0000032
VCID: 33331094772871436A3-4B00
Subsystem 1 - Part No: 3W1 959 701
Component: Tuersteuergeraet FS 0702
Subsystem 2 - Part No: 3W1 959 702
Component: Tuersteuergeraet BF 0702
Subsystem 3 - Component: TSG HL No Answer
Subsystem 4 - Part No: 3W3 959 704
Component: Tuersteuergeraet HR 0702
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0020
1 Fault Found:
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W0 035 456 C
Component: 12K-AUDIOVERST 4121
VCID: 343113887226767B739-5160
Address 65: Tire Pressure Labels: 3D0-907-273-V1.clb
Part No: 3W0 907 273
Component: Reifendruckueberw. 0022
Coding: 0010344
Shop #: WSC 03236 104 61216
VCID: 76B5E98024DA246B8DD-5160
Address 71: Battery Charger Labels:
Address 76: Park Assist Labels: 3W0-919-283-V1.clb
Part No: 3W0 919 283
Component: 02 Einparkhilfe 0203
VCID: 7AADFDB010C2400BE95-5160
Address 77: Telephone Labels: None
Part No: 3W0 035 729 K
Component: Telefon 0252
End----(Elapsed Time: 08:34, VBatt start/end: 10.3V/10.4V. VIgn 0.0V)------
Coding: 0000173
15 Faults Found:
P1923 - 008 -
17994 - Engine Mount Solenoid Valves (N144/N145)
P1586 - 001 - Short to Plus
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 -
Coding: 0131309
Component: ELV XXXX
3 Faults Found:
00087 - Terminal 30 for Starting Relevant Consumers
Coding: 0000002
7 Faults Found:
Coding: 0000002
2 Faults Found:
00926 - Terminal 30
Coding: 0000012
Coding: 0000002
13 Faults Found:
Coding: 0000189
Coding: 0000032
1 Fault Found:
Coding: 0010344
1 Fault Found:
013 - Check DTC Memory - MIL ON
End-----(Elapsed Time: 08:41, VBatt start/end: 10.2V/9.2V. VIgn 0.0V)------
After Start
Code:
Friday,11,February,2022,18:21:00:53661
www.Ross-Tech.com
Coding: 0000173
15 Faults Found:
P1923 - 008 -
P1570 - 008 -
Coding: 0131309
Component: ELV XXXX
3 Faults Found:
Coding: 0000002
7 Faults Found:
Coding: 0000002
2 Faults Found:
00926 - Terminal 30
Coding: 0000012
Coding: 0000002
13 Faults Found:
Coding: 0000189
Coding: 0000032
1 Fault Found:
Coding: 0010344
1 Fault Found:
@V12diablo ,
When you are starting the engine, are you in the vehicle with all doors closed, if so, does the dash display any message of immobilizer, as your engine cutting out after 2 seconds, is exactly what the immobilizer does, see my video, but of course I knew I had an issue, as I was installing the 2011 Supersports engine, transmission, and ecu's, the 2011 ecu's did not match my 2006 KESSY module skc/pins, so I reworked the 2011 ecu's to work.
Your issue is either the KESSY is or was wet at some point, or the same for your ecu's up at the cowl, or you have an issue with terminal 30 lack of power, or shorting out, like a wet KESSY, or ecu's.
I will check all the fuses tomorrow at both fuse boxes. Also once the drives seat is out is the carpet fairly easy to remove or is there any tricks to getting it out, I just don’t want to damage anything. I have come to realize this car is built totally different from any other car I have worked on. And thank you for all the help so far.
Jason
@V12diablo ,
It is not just the 2 fuse boxes, meaning the cowl and dash, also check all fuses above the house (left) battery, along with the mega fuses mounted on the house battery, there are also fuses mounted on the starter battery (right side).
As far as removing the seat, I would first remove the kick plate (hood release handle) trim, and sill plate to lift the carpet up to access the kessy module, if you do choose to remove the seat, PLEASE, put lots of heavy towels over the sill/rocker to protect it, the seat is awkward to remove from the vehicle.
If you choose to remove the carpet completely, be sure to remove the throttle kick down switch trim piece first, I broke one my first time, remove the 2 plugs to access the 2 screw heads for removal.
